Drivetrain Any Opinions on Clutchmasters Steel flywheel?
Anyone have any experience on the Clutchmasters lightweight steel flywheel? I'm looking to install a 6-speed onto my R50 for a budget "track use only" car and I would prefer to keep the flywheel closer to the stock R50 weight rather than go up to the R53 flywheel weights. I was looking at the Clutchmasters steel flywheel at something like 17lbs
FW801SF
Because it is an unsprung / solid mass flywheel, what are my clutch friction disc and pressure plate options with this flywheel?
I'm trying to keep it under $500 all-in for a lightweight flywheel, friction disc and pressure plate. I have a stock dual mass flywheel setup and a luk brand dual mass flywheel, both used, that I can scavenge parts (pressure plates) from.
FW801SF
FW801SF
FW801SF
