R58 Coupe Wiper Blades.......
Old Nov 23, 2017 | 07:23 PM
dube53's Avatar
dube53
Any suggestion where to find good wiper blades to replace the OEM installed at the dealer during the maintenance program?
I found Trico Rain Guard with the same low profile attachment but they are garbage after less than a month.
Old Nov 26, 2017 | 07:00 AM
Deli's Avatar
Deli
I'm also looking for a recommendation here...
Old Nov 28, 2017 | 07:31 AM
smith80678's Avatar
smith80678
You can get Bosch Wipers at Pep Boys. Worked really well for me.
Old Nov 28, 2017 | 07:43 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
go with the Piaa blades. They work so much better and will last longer
https://www.waymotorworks.com/piaa-w...s-r58-r59.html
Old Nov 28, 2017 | 05:46 PM
dube53's Avatar
dube53
The problem is to find a frameless, flat and low profile blade set up with a streamline attachment that doesn't raise the wiper arm.
I am wondering if there is a way to replace just the rubber blades with silicone refills and keep this same low profile mounting bracket.
Old Nov 30, 2017 | 06:35 PM
Tigger2011's Avatar
Tigger2011
Alliance Member
+1 for PIAA. Silicone will definitely last longer. The heat here in FL kills rubber wipers quick.
Old Nov 30, 2017 | 07:35 PM
dube53's Avatar
dube53
I installed the OEM back and returned the Trico which are real garbage. At least for now, the old ones are better.
A local AutoValue store found Anco..... never heard of that before. They will have by tomorrow to figure if they fit. I live in WA and its like living in the middle of nowhere. PIAA Silicone rubber........they don't even have them listed.
It seems I have to travel to civilization to find them at a Pep Boys store somewhere in Seattle as the O'reillys guy told me.
Old Dec 1, 2017 | 10:29 AM
Tigger2011's Avatar
Tigger2011
Alliance Member
Amazon
PIAA 97050 - 20" $26.44
PIAA 97053 - 21" $27.69
Old Dec 1, 2017 | 11:39 AM
LostbutFound's Avatar
LostbutFound
Amazon
PIAA 97050 - 20†$26.44
PIAA 97053 - 21†$27.69
Glad you posted that. I went to one wiper site and it said 18" and 19" but a different one said 20" and 21". I believe you should know what's correct. Thanks.
Old Dec 1, 2017 | 12:17 PM
Tigger2011's Avatar
Tigger2011
Alliance Member
These are what I'm running on Vlad now. They also come with wipes used to prep the windshield during installation. Basically a Rain-X type wipe to help water bead up and roll off. You only need one so you can save the other for later.
Old Dec 1, 2017 | 05:16 PM
dube53's Avatar
dube53
You need 20" and 21".
I received the Anco from the parts store. I will see during the week how they perform otherwise they will go back.
I also remove the RainX coating from my windshield because I have the feeling this is also part of the problem as rhe local automotive glass shop told me. The wipers have a tendency from time to time to wobble on the glass.
I never had this problem before until I started to use RainX a few months ago.
Old Dec 1, 2017 | 06:19 PM
Tigger2011's Avatar
Tigger2011
Alliance Member
Same here. Tried Rain-X and had a problem with the blades jumping. Haven’t had that issue with the PIAA wipers. Don’t know if it’s the silicone which is a lot more flexible or if the PIAA wipes use a different formulation.
Old Dec 3, 2017 | 06:54 PM
dube53's Avatar
dube53
Both of us are certainly right. I have the Anco blades installed since the last 3 days and they are certainly better than the Trico. It rains here everyday now in WA so I can figure out better.
I cleaned my windshield with rubbing alcohol as recommended by the glass shop to get rid of the wax. Everything is a lot smoother with no streaks but I am not sure I will keep these either. They seem to be noisy compared to the old OEM.
Old Dec 11, 2017 | 06:45 PM
dube53's Avatar
dube53
Do you have a photo of the PIAA installed on your Coupe?
I am not sure I will keep the Anco. They are less stiffer than the Trico but far from perfect fit.
Old Dec 12, 2017 | 05:31 AM
Tigger2011's Avatar
Tigger2011
Alliance Member
Old Jan 9, 2018 | 07:48 PM
dube53's Avatar
dube53
I installed the PIAA I received last week. It rained this afternoon and I can see a big improvement over the Trico and Anco aftermarket products I tried and returned in the last 2 months. My older OEM were even far better every time I put them back.
I believe the OEM still fit better because the wiper arms sit lower to the cowl with no need for an adapter and the OEM are also more streamlined, slimmer and less bulky at the bottom of the windshield.
The Coupe ranked windshield has a larger surface to cover than other models. The PIAA product is for sure the best aftermarket wiper I found until now.
Old Jan 10, 2018 | 09:05 AM
WayMotorWorks
Vendor
That's what we have been saying about the Piaa they are just great. Also they will last so much longer.
Old Jan 10, 2018 | 06:03 PM
dube53's Avatar
dube53
I just hope I will become accustomed with the higher wiper arm standing with big gap over the blade adapter because they really show up at the bottom of the windshield when driving and you have the white PIAA script in your face all the time. This is a distraction.
Overall, they should have designed a better adapter.
Old Jan 13, 2018 | 04:29 AM
rdblkcoupe13's Avatar
rdblkcoupe13
End Cap
I have lost the little cap thingy that goes on the end. Any ideas where I could buy a replacement part? The blades are in great shape no need to replace at the moment. Just hate driving down the road in my sweet ride and see that missing.
