Is the Rear Camber adjustable ?
Old Nov 13, 2017 | 11:49 AM
pbkirby's Avatar
pbkirby
Had an alignment at the Mini Dealer over a year ago and the rear camber is at -2 degrees. Getting excessive inner should wear and cupping. Was going to have the alignment redone to fix the issue, want to be sure the rear camber is adjustable. I rotate every 5K.
Old Nov 13, 2017 | 12:11 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
-2° camber is NOT excessive. You want to make sure the TOE is set correctly on both sides. Correct toe setting is MUCH more important than camber.
Of course, whatever the alignment numbers come out to be, you want to make damn sure the numbers are the same on both sides.
Old Nov 13, 2017 | 03:13 PM
pbkirby's Avatar
pbkirby
Toe was set to
Front L:0.10', R 0.08'
Rear L:0.09', R 0.14'
Old Nov 13, 2017 | 04:48 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Camber at 2 degrees is actually within tolerance for the sport suspension R60
https://www.newtis.info/tisv2/a/en/r...ement/EGs22DrN
Something else must be out.
Old Nov 13, 2017 | 05:31 PM
Subw00er's Avatar
Subw00er
Wow that looks like a tire defect to me.
Old Nov 14, 2017 | 06:54 AM
pbkirby's Avatar
pbkirby
Third set this has occurred
Definitely and alignment or suspension issue
