Is the Rear Camber adjustable ?
-2° camber is NOT excessive. You want to make sure the TOE is set correctly on both sides. Correct toe setting is MUCH more important than camber.
Of course, whatever the alignment numbers come out to be, you want to make damn sure the numbers are the same on both sides.
Camber at 2 degrees is actually within tolerance for the sport suspension R60
https://www.newtis.info/tisv2/a/en/r...ement/EGs22DrN
Something else must be out.
