Suspension R56 front sway bar DIY?
Old Nov 9, 2017 | 08:11 PM
Pramuk's Avatar
Pramuk
I just got front sway bar and thinking to install it by myself. yesterday I took it to mechanic and it costs over $350 to install. any suggestion?, specific tools?
Old Nov 10, 2017 | 03:41 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Install cost is high because you have to lower the front subframe, which isn't a difficult task, it can be very time consuming. Most don’t bother with the front bar because of that fact.
Old Nov 11, 2017 | 09:06 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Like he said you do have to remove the front subframe. It isn't hard but will take some time. And you have to remove the exhaust first.
If you are going through this trouble go ahead and get a set of our powerflex front control arm bushings so you don't have to do this again just to do the bushings later.
Old Nov 16, 2017 | 07:05 AM
Burglar's Avatar
Burglar
Took me the good part of a day to do mine, real PITA of a job. Agree with above, throw on a fresh pair of control arm bushings while you are in there. One of the bolts is shared between the swaybar bracket and bushing bracket.
