R56 Upcoming Service Projects
Old Nov 4, 2017 | 06:01 PM
Rrtec's Avatar
Rrtec
I’m going to do the following services next weekend..Wondering if there is anything I’m missing..
1) oil filter housing gasket
2) oil cooler gasket
3) valve cover gasket
4) spark plugs
5) oil change
6) vacuum pump
7)air filter
Any other no brainers while I’m digging in?
Old Nov 4, 2017 | 08:38 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Having it that far apart is a good time to upgrade to our stainless oil line kit
http://waymotorworks.com/wmw-stainle...-line-kit.html
Old Nov 8, 2017 | 05:21 AM
seandallen's Avatar
seandallen
Transmission fluid and filter?
Old Nov 8, 2017 | 03:03 PM
3lusive's Avatar
3lusive
When you replace the oil filter housing gasket you'll dump alot of coolant, so you might as well do a coolant flush. Drain both oil and coolant at the beginning of the services. +1 to way's recommendation of turbo oil line, you have everything apart at that point and it's a known point of failure.
Old Nov 9, 2017 | 04:17 AM
Rrtec's Avatar
Rrtec
What about timing chain tensioner? Is that a fairly accessible change out?
Old Nov 9, 2017 | 11:55 PM
Scudder44's Avatar
Scudder44
On a basic Cooper, very easy, removal of air intake pipework to gain access. On an S, bit more to remove. Guides at Pelican Parts and Youtube.
Old Nov 10, 2017 | 07:57 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Yes, be sure to use our tech articles and if you have any questions leave a comment at the bottom of one and one of our techs will have an answer for you. I am also here to help!
http://www.pelicanparts.com/techarti...r_R56_Tech.htm
888.280.7799 | 6am - 5pm PST
