R56 On board diagnostic codes Need help
Old Oct 24, 2017 | 07:15 PM
shanksamillion's Avatar
shanksamillion
I've searched everywhere and cant find anything. I'm trying to find out what the on board diagnostic codes mean. This is from the instrument cluster under number 14. It appears to be a hexadecimal code. I don't know. So first it shows the number of errors in the system. Then you can scroll through each one. I suspect some of these codes are related to my fog lights which aren't working because I hit some debris on the road and it ripped up my wheel well and frayed the wires there. I also have the dsc and brake lights on which appears to be switch unit steering angle sensor failure. I do realize that I likely need to replace the switch unit, but maybe not. I've read bad LCA bushings and links can cause this failure. Anyway here are the codes. First there is a four digit code followed by an h. Then a longer number underneath.
Err 1 4314 h
20004F028B00
Err 2 931D h
200057F2B800
Err 3 931B h
200057F27D00
Err 4 A3AC h
200057F27701
Err 5 A3A9 h
200057F27D00
Err 6 A550 h
200058107701
Err 7 A3B9 h
(forgot this one I think its the same as Err 5)
