F60 2018 Countryman ALL4 backup camera
Probably a weird question, but does anyone know how to remove the backup camera on a 2017/2018 Countryman ALL4? I took mine to a shop for some accessories and they removed and reinstalled the backup camera UPSIDE DOWN. I'm concerned that if I take it back to them, they may jack up something else, and wanted to see if I can fix it myself.
Any insight would be appreciated.
I was first guy ever to successfully retrofit an OEM camera into an F56 (with the help of Bimmertech). Fun times!
It looks a little bit different than the F56's, but there, I had to remove the inner panel on the hatch and the camera was a cube-shapped unit, with a cable that easily detaches. The camera shaped into a holder. If similar, you could access it and turn it 180°, and snap it back in. It was three years ago that I did this, so it's a bit hard to recall exactly, but I do remember the camera cube itself just popping in and out of the holder quite readily.
https://www.newtis.info/tisv2/a/en/f...era/1VnZ4pdUBa
From the looks of the instructions, there shouldn't be a way for that to go in upside down with the two screws and the orientation...
Originally Posted by f60jcw
This should show you how:
Thanks everyone for the inputs and info. Even the owner of the place was perplexed on how the camera got reinstalled upside down. He's going to fix it tonight, so we'll see if it comes right-side up this time. I'll be prepping my tools just in case though...
I'm tempted...My OCD is kicking in.
