Suspension R53 front sway bar endlinks hitting axle
Old Oct 4, 2017 | 09:51 AM
BoringR53's Avatar
BoringR53
Hi guys, looking for some input on what I should do to fix the front sway bar endlinks from hitting the axles. It's on both sides. Car is lowered 1.5 all around. Do I need adjustable endlinks or is there something else I should be looking for? I will try to get better pictures today. Thanks!
Old Oct 4, 2017 | 03:02 PM
BoringR53's Avatar
BoringR53
Old Oct 4, 2017 | 03:53 PM
Subw00er's Avatar
Subw00er
Can you just flip them to the other side of the bar?!
Old Oct 4, 2017 | 09:13 PM
BoringR53's Avatar
BoringR53
Not sure. I have been trying to find out. If I can't find confirmation then I will on Saturday.
Old Oct 6, 2017 | 07:26 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
those appear to be some aftermarket end links that are made wrong as they are too big on that end. You unfortunately can't put it on the otherside of the bar as it then won't fit the strut.
Here are some proper ones that will work
https://www.waymotorworks.com/sway-b...0-r52-r53.html
Old Oct 6, 2017 | 08:07 PM
BoringR53's Avatar
BoringR53
Thanks for the heads up about not being able to flip them. My sway bar is angled very far down like 45 degrees. So I’m thinking I should get adjustable end links.
