2nd Gen Countryman (F60) Talk (2016-2024) Second Generation Countryman discussion. F60
F60 Door Unlock Question
Old Oct 2, 2017 | 05:22 AM
BDI's Avatar
BDI
On my VW/Audi's, if you press the Unlock Button on the remote once it unlocks the drivers door. Pressing it twice unlocks all the doors.
I noticed it does not do this on the Mini. Is there any way to do this?
Old Oct 2, 2017 | 06:00 AM
pyuhlu's Avatar
pyuhlu
Yes. The settings are part of the driver profile and you can check on page 57 from the manual
Old Oct 2, 2017 | 06:28 AM
BDI's Avatar
BDI
I saw that but unfortunately you can only set it to either...
1) Driver Only
or
2) All Doors
I'm looking to do.
1 Click - Drivers Door
2 Clicks - All Doors
Old Oct 2, 2017 | 06:39 AM
pyuhlu's Avatar
pyuhlu
1) Driver Only
or
2) All Doors
I'm looking to do.
I tried like you wanted and it works with the keyless entry
Old Oct 2, 2017 | 06:45 AM
BDI's Avatar
BDI
Thanks! I will try again when I get home.
I'm pretty sure when I hit the keyless entry button on the door handle twice it just unlocks then locks the car.
Old Oct 2, 2017 | 06:49 AM
pyuhlu's Avatar
pyuhlu
Similar to my 04 VW Treg. Too many high tech on it then and I had no idea how to master it
Old Oct 2, 2017 | 08:11 AM
MrFunk's Avatar
MrFunk
I tried this morning as well. It works as described.
Old Oct 2, 2017 | 09:03 AM
BDI's Avatar
BDI
I will try again. I have the setting to unlock the driver's door. Will all your doors unlock if you press your keyfob twice?
Old Oct 4, 2017 | 05:37 PM
BDI's Avatar
BDI
So because my profile is set to unlock the driver's door only via settings, Only the driver's door unlocks via drivers door handle button. If I press the passenger door button, all the doors open.
Just like a lot of you said, pressing the unlock on the keyfob once unlocks the drivers door. Pressing it twice unlocks all the doors.
Again, thank you all!! This board is awesome! Hopefully it becomes more active!!
Old Oct 4, 2017 | 06:17 PM
(SM)'s Avatar
(SM)
Has anyone had any luck with the side mirrors folding in/out when you lock/unlock? According to the manual it is possible with the fob, but haven't managed to get it to work.
