Turbo heat shield necessary?
Old Sep 18, 2017 | 07:34 AM
cstrumol's Avatar
cstrumol
Anyone running daily without their turbo heat shield? Ever since I removed mine for the DP install it has started to rattle at low rpms. If there is no real downside to removing it, I think I remove totally to get rid of this noise. Let me know your experiences. I have an R60.
Thanks,
Old Sep 18, 2017 | 08:06 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
The heat shields are there to protect the components around them from excessive heat. No way would I run mine without them. Also, the shields all bolt together, so if you remove one, you're bound to get some rattling somewhere. If I were you, I'd get that removed shield back on as soon as possible.
Old Sep 18, 2017 | 09:21 AM
cstrumol's Avatar
cstrumol
It is currently on, it just rattles. I'll have to investigate how I can fix that. Perhaps I bent it when removing and now it makes contact somewhere.
Old Sep 18, 2017 | 02:17 PM
godskid's Avatar
godskid
Not sure what model you are referring to, but my 2009 S hardtop was burning up hood stripes (down the middle; I didn't install them initially so didn't choose that location) until the dealer installed the heat shield.
Old Sep 18, 2017 | 08:39 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Do NOT drive it without the top heat shield in place. You will end up melting the valve cover. We've seen this happen more than once.
Old Sep 20, 2017 | 07:39 AM
cstrumol's Avatar
cstrumol
I tried bending last night and seems to have gotten better as of this morning but I can still hear it with the windows down. Might just cave and get a blanket. Almost time for a new turbo anyway (102k on this one) and I don't know if the new 47mm will fit under the stock shield anyway.
Old Sep 22, 2017 | 12:38 PM
bugeye1031's Avatar
bugeye1031
Moderator
Pretty sure the larger turbo will fit under the stock shield. I have WMW's blanket under my stock shield in my JCW....works well.
Old Sep 28, 2017 | 08:53 PM
Minicoopersmodel's Avatar
Minicoopersmodel
Use thread lock glue on the screw.
Old Sep 29, 2017 | 06:56 AM
cstrumol's Avatar
cstrumol
Will give this a try! I'm actually starting to think it is the wastegate thats jingling around. New turbo going on this weekend so we will see!
