D Stock Brakes
Brakes
Okay read through the FAQ and didn't see anything mentioning brakes there. So I searched through the internet and found a rule listing stating
- The make and material of brake linings may be changed.
- Substitution of clutch and brake hydraulic lines with solid metal or braided metal is allowed on all cars manufactured before model year 1992.
- Alternate brake bleeder fittings such as "Speedbleeders" are permitted They may serve no other purpose.
Ok I'll be a smarta$$... does lining sound like rotors? Lining is the friction material of pads and shoes.
The short answer is Yes you can replace the rotors (they wear out) but you have to replace them with OEM or equivalent. No drilled or slotted rotors, no big brake kits, etc
I'm assuming that the stock brake lines aren't braded (my mini is on a boat currently, so I cant look). My first "mods" will be better pads, fluid, and bradded lines. I have goodrich lines on my other auto-x cars and it makes a noticeable difference in brake pedal feel.
Originally Posted by JustGo4It_
original mini doesnt run in G stock....Try Prepared Class D
Tinklespout
16
Sep 6, 2015 11:39 AM
PelicanParts.com
Tires, Wheels & Brakes
Sep 3, 2015 03:22 PM
