R56 intake piping separating? (photo)
Old Sep 12, 2017 | 09:39 AM
shakeypuddin's Avatar
shakeypuddin
losing power @ 4k RPM after a major hiccup/stumble. Whats this piece with a gasket sticking out of it so I can repair? Is there a better than stock way to fix? Thanks guys, First time poster... long time lurker. Just want to get this buttoned up so I clear the CEL code running rich at idle, and get my boost back.
in case you are wondering... this happened a few times... my buddy and i came up with cheap solution put 2 zip ties around the mating surfaces of each piece then zip tie the zip ties together as a way of holding these pipe in place. well... that worked for about 1.5 tanks of fuel.
Old Sep 12, 2017 | 09:53 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
that's the noise maker inlet pipe. your solution is right here:
https://www.ecstuning.com/b-forge-pa.../fmr56obh~frg/
Old Sep 13, 2017 | 12:31 PM
shakeypuddin
Thank you!
Ordering it up right now!
will post upon install.
Old Sep 18, 2017 | 09:37 AM
Yep,
Dont forget there are 3 color options, black, red, and blue
https://www.ecstuning.com/Search/SiteSearch/FMR56OBH/
Old Sep 28, 2017 | 08:12 AM
BigBoost's Avatar
BigBoost
You lost that clip didn't ya?
