Suspension opinions on aftermarket r52/r53 strut mounts needed
Old Sep 11, 2017 | 10:43 PM
Subw00er's Avatar
Subw00er
The Oem's are expensive! Has anyone had success with any of the aftermarket ones? Do any of them give a performance enhancement ala reducing cornering setup, mid corner correction stability, or improving directional (other than the camber plates, dont want to do that).
https://www.ecstuning.com/Mini--Coop...h/31306778833/
Old Sep 12, 2017 | 07:14 AM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
I suggest you look into Ireland Engineering fixed camber plate. Like OEM, but with ~1.5 degree more negative camber. Built in tower protection.
Old Sep 12, 2017 | 07:23 AM
gumbedamit's Avatar
gumbedamit
Lemforder.
Old Sep 12, 2017 | 07:37 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
go with ireland engineering if you want more performance, or lemforder imo
Old Sep 12, 2017 | 08:41 AM
Subw00er's Avatar
Subw00er
Thanks for suggestions. What are you guys seeing for inside tire wear with the -1.5deg plates? Big difference or minor? Im planning on doing the 22mm wmw rear sway. Will -1.5 plates complement the alta or will it want to oversteer too much? Anyone have this setup?
Old Sep 12, 2017 | 08:52 AM
pnwR53S's Avatar
pnwR53S
Old Sep 12, 2017 | 09:18 AM
MrBlah's Avatar
MrBlah
I don't daily my car much, and have -3.5 and I don't notice inside wear because track & autocross use ruins the outside edge faster
Old Sep 12, 2017 | 02:19 PM
Subw00er's Avatar
Subw00er
Yah, this is a daily driver for me.
Old Sep 13, 2017 | 08:31 PM
Subw00er's Avatar
Subw00er
I think I'll go with the ireland fixed plates and also planing on the alta 22mm rear sway. Does anyone have this setup? Whats it like?
Old Dec 31, 2017 | 04:55 PM
Andrew Riley's Avatar
Andrew Riley
I'm in the same boat as you, need new strut mounts, like yesterday.
I'm having a hard time deciding what makes the IE the "GO-TO" for everyone. I was thinking Lemforder, then using the saving for a nice strut brace?
Hell, I can even make my own 1/2" thick steel STD's. So not worried about the mushrooming in the future. Anyway, OP, what route did you go and how's it been for you?
Old Jan 1, 2018 | 07:03 PM
Andrew Riley
Anyone want to chime in. I plan on placing the order tomorrow and unless someone can really inform me as to why the IE Mounts are the absolute best, go-to everytime...
I'll probably order Lemforder brand mounts, make my own STDs, and use the saved money for a strut brace.
Thoughts please?
Happy New Year MINIACS!
