Rebuild abs module
Old Sep 11, 2017 | 02:50 PM
Eric.'s Avatar
Eric.
Rebuild abs module
ive had the trifecta abs lights coming on in my mini recently. I pulled the code and it's a supply voltage issue. I was wondering if there is somewhere that rebuilds these abs modules? I tried module master but they said they don't work with this module. I know you can buy a used module and get it coded to you car I'm just trying to find the best fix price wise. Thanks for the help
Old Sep 12, 2017 | 06:23 AM
MiniToBe's Avatar
MiniToBe
your ABS could be fine. when the battery goes low or dies, most modules will report the same/similar codes. clear the code. of it comes back, you might have to "reflash" it using NCSexpert.
where you located?
Old Sep 12, 2017 | 03:15 PM
Eric.'s Avatar
Eric.
I cleared the code and it came back on as soon as I moved the car, 5d8c is the code DSC wheel speed sensor supply, front left. I check the live data and even while not moving it says the wheel is going 158mph. I'm located in the Seattle area
Old Sep 12, 2017 | 07:21 PM
MiniToBe's Avatar
MiniToBe
Abs sensor on that wheel is probably faulty. I think they're cheap. Not sure if you can swap sensors to see if code movea with it!
Old Sep 13, 2017 | 04:26 AM
Eric.'s Avatar
Eric.
already swapped the sensor and checked with the sensor unplugged, getting the same results.
Old Sep 13, 2017 | 05:21 AM
MiniToBe's Avatar
MiniToBe
if you have NCSexpert, you can buy a used module and coded. the software is worth the money
Old Sep 13, 2017 | 07:45 AM
Eric.'s Avatar
Eric.
I'll check it out thanks for the info
