How to know if friction wheel needs replacing?
Old Sep 8, 2017 | 03:39 PM
solankill's Avatar
solankill
Hello, I have a 2009 Mini Cooper Base Model
My question is how do you know when you need to change the belt tensioner/friction wheel. My car was overheating and leaking from the water pump so we changed the water pump, the pulley, and the belt, but it is still over heating. When I checked, I see that the actual water pump pulley is not spinning.
Could this be a problem with the tensioner or friction wheel not being tight enough to move the pulley?
Old Sep 8, 2017 | 07:24 PM
Tigger2011's Avatar
Tigger2011
Alliance Member
Was the release tab for the friction wheel pushed back in after changing the belts. If so pull it back out to release the friction wheel. Rotate the water pump pulley by hand. If it rotates freely push the friction wheel tab back in and start the car. If still no joy its time for a new friction wheel assy.
Old Sep 9, 2017 | 10:40 AM
solankill's Avatar
solankill
So after closer inspection, I see that the friction wheel was the problem, and after much struggle I was finally able to get it out.
Is there an easier way to get this thing out? I lowered the engine block but only one of the bolts was easily accessible, the rest were really hard to get to and not a lot of space to work on. I am worried installing the new part will be very difficult.
Attached for your amusement is the friction wheel which is practically torn apart. (no idea how this happened), any thoughts?
