Navigation & Audio Can Valentine 1 be tapped into clock?
Old Sep 7, 2017 | 10:39 AM
Sugeray's Avatar
Sugeray
I'm sorry if this was answered before but I can't find any information: can I tap into the power from the digital clock on the ceiling?
BTW, how do you remove that clock cover?
Cheers,
Ray
Old Sep 8, 2017 | 02:09 PM
Whine not Walnuts's Avatar
Whine not Walnuts
You have a Gen1 car correct?
Old Sep 8, 2017 | 02:21 PM
Sugeray's Avatar
Sugeray
Yes, 2003 MCS...
Old Sep 8, 2017 | 04:16 PM
Whine not Walnuts
I cannot remember a clock on the headliner with my R53, perhaps it was an option. If the clock is in with the sunroof control I am thinking it has small plastic tabs that push in place. Should be able to pry out with a soft too.
Old Sep 8, 2017 | 07:31 PM
Sugeray's Avatar
Sugeray
But is the clock wiring enough to power the Valentine 1 detector?
Old Sep 8, 2017 | 09:15 PM
Eric_Rowland's Avatar
Eric_Rowland
Yes. V1 doesn't draw that much power.
Old Sep 15, 2017 | 09:56 AM
ApexinM3's Avatar
ApexinM3
I tapped mine off a fuse in the fuse box on the left kick panel area using a piggy-back fuse block then ran the wires up the post, under the headliner, and down the front of the mirror. Works like a champ.
Old Sep 15, 2017 | 10:21 AM
Sugeray's Avatar
Sugeray
So did you do that because the clock wires can't support the Valentine 1?
Old Sep 16, 2017 | 03:08 PM
ApexinM3's Avatar
ApexinM3
I'm sure the OEM wiring will support the V1, I just don't like splicing. I cringed when I had to splice into the wiring for my steering wheel stereo control module. Just a pet peeve of mine, and I'm OCD.
Old Dec 16, 2017 | 03:48 PM
Radcap's Avatar
Radcap
Just looking at the idea of running my V1 from the fuse panel as well, what did you do for the grounding wire, not much there for selection. A pic or description would be great, I had it all wired but couldnt find a suitable ground for the piggy back and what fuse did you piggy off of?
thanks
Old Dec 18, 2017 | 04:43 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
use a tap on the dome light power
Old Dec 18, 2017 | 07:13 AM
Sugeray's Avatar
Sugeray
I used those vampire taps: Red/green is the power and grey/brown is the ground...
Old Dec 18, 2017 | 07:56 AM
Radcap's Avatar
Radcap
Thanks, I would still rather go at it from the fuse panel as I am a bit more comfortable than splicing wires, I just had foot surgery so I have a couple weeks(5-6) yet to mull it over before my way better half allows me to get back to the garage����. Not much room to work but I guess that goes with the overall footprint. Fun to drive so far!
Old Dec 18, 2017 | 08:39 AM
MrBlah's Avatar
MrBlah
I would never splice a harness, I use either vampire tap (ok) or a posi-tap (best)
Old Dec 18, 2017 | 10:07 AM
gumbedamit's Avatar
gumbedamit
+1
That's what I use. When I open my door my RD powers up, and when I lock the car, it powers down when the dome light goes off.
