Suspension Sway bar sizing..
Old Aug 27, 2017 | 09:21 PM
neopill's Avatar
neopill
Sway bar sizing..
R56 2009 Mini Cooper S Sports Packaged or Premium Packaged.
I want to know what MM size are my front sway bar so I can buy the correct bushings for it.
Old Aug 28, 2017 | 08:27 AM
mbwicz's Avatar
mbwicz
I think its 24mm, but not 100% sure. Its not hard to measure, but the bushings are a pretty big job to replace. You can probably measure it if you just turn the wheels all the way and reach behind the tire.
You should do the lower control arm bushings at the same time. If you're worried about the sway bar bushings being worn, your control arm bushings are probably shot also. You have to drop the front subframe to get to them, including unbolting the rack. Its not hard work, just a decent amount of parts to remove.
Have fun,
Mike
atlantaorange
Suspension
18
Dec 26, 2016 10:16 PM
bratling
Dec 2, 2016 02:04 PM
SneedSpeed
Sep 21, 2016 07:02 AM
66stang21
Suspension
Sep 10, 2016 08:49 PM
dave
Suspension
Dec 21, 2002 05:42 PM
