Leaves in Bodywork Can't Remove
Old Aug 26, 2017 | 05:46 PM
Max Schrank's Avatar
Max Schrank
Hi, I can see leaves caught in the bodywork in front the the doors in the space between the wheel and the door frame. You can also see them from the top when the hood is up. I've attached some pics. I expect most of these cars have this issue if they're parked outside. Has anyone found an easy way to clean them out? I tried a screw driver but doesn't really get in the enough and will scratch the paint/rust proofing. Thanks,
Attached Thumbnails Leaves in Bodywork Can't Remove-img_5604.jpg   Leaves in Bodywork Can't Remove-img_5605.jpg   Leaves in Bodywork Can't Remove-img_5606.jpg
Old Aug 26, 2017 | 06:03 PM
Cngizbleevng's Avatar
Cngizbleevng
Maybe try an air compressor and nozzle.
Old Aug 26, 2017 | 07:10 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
shop vac with small section of old garden hose duct taped to end.......?
Old Aug 27, 2017 | 07:42 AM
Whine not Walnuts's Avatar
Whine not Walnuts
I have headlamp washers so between that bottle and the windshield bottle on the other side I cannot see down into the void but would think if you remove the plastic fender/wheel shield you could clean the area out.
Old Aug 27, 2017 | 07:43 AM
Whine not Walnuts
Where is the first picture?
Old Aug 27, 2017 | 10:43 AM
H_C's Avatar
H_C
A strong vacuum cleaner can suck those leaves out.
Old Aug 27, 2017 | 11:58 AM
Antmax's Avatar
Antmax
My MX5 had the same thing. The leaves turned to potting soil and some weeds started sprouting at one point. I used an air compressorvto blast the loose stuff when dry and a house when cleaning the car finishing up with the compressor again.
i havent had the mini through an Autumn yet. Mx5 didn't have a air filter for the cabin ac blower. When leaves for in and started to rattle you knew to blast them out elsewhere too.
Old Aug 27, 2017 | 01:38 PM
cerenkov's Avatar
cerenkov
You can actually remove the wheel well liner and clean it out. I cleaned my out when I was installing a big brake kit.
Old Aug 27, 2017 | 10:47 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
^ this. Been there done that.
Old Aug 28, 2017 | 04:03 PM
MiniCooper_S's Avatar
MiniCooper_S
Shop vac from inside the engine bay. You don't have to take anything apart. Done this a couple times on my r56 with no issue.
Definiteley get them out asap though because when they get wet and sit for long periods of time there can be rust developing on the inside of the fender.
Old Aug 28, 2017 | 04:37 PM
ptiller's Avatar
ptiller
+1 for remove wheel well liner, did that on the R56
Old Aug 28, 2017 | 06:02 PM
squawSkiBum
Moderator
Shop vac from the top will only get about 80%, plus it is a PITA since you need a long narrow tube to get down to the bottom. You only have to take out one or two fasteners to pull the back corner of the fender liner back, but you do need to take the wheel off. I had a nice compost pile starting. Grabbed the hose and a soft brush and cleaned it out. Now it is one of the things I check when I rotate the tires.
Old Aug 28, 2017 | 09:14 PM
cjv2's Avatar
cjv2
Thanks for this. I'm getting ready to do front brake pad replacement and will make this part of the work. My motivation: used Mini, owned less than a month, came with sugar ants. They had made those organic debris chambers their home!
Old Aug 29, 2017 | 03:44 PM
J Free's Avatar
J Free
I've used air compressor/shop vac and this
http://www.homedepot.com/p/GrabEasy-...0401/202505170
Old Aug 30, 2017 | 03:10 AM
cristo's Avatar
cristo
Alliance Member
I use something like this for such stuff:
Amazon Amazon
Old Aug 30, 2017 | 02:04 PM
Max Schrank
Thanks all! I tried the vacuum and grabber so far with 80% success. I'll go for the full removal of wheel well liner at the next rotation. I really appreciate all the responses.
Old Aug 31, 2017 | 05:55 AM
Air compressor and some time should get them all out, or a big leaf blower.
