Decided to change alternator
Old Aug 12, 2017 | 05:18 PM
JoeM56's Avatar
JoeM56
I posted earlier about a problem with my new battery charging. I checked it again this morning and the alternator has output for a few minutes then quits. I decided to try to remove the alternator however I can not get the front radiator and bumper to slide into the maintenance position. everything is disconnected per the manual. I can feel the lower braces are free, fender bolts are removed and everything is free on top, what am i missing, it wont budge.
Old Aug 12, 2017 | 07:15 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Check out the below Vid by ModMini, notice how Mod and God are very similar, and then get back with us on questions. Radiator only "slides" out if you have a longer bolt to put in so that it will.
Old Aug 12, 2017 | 07:27 PM
MiniToBe's Avatar
MiniToBe
pix?
Old Aug 13, 2017 | 04:52 AM
JoeM56's Avatar
JoeM56
Thanks for the video but I have a 2007 non turbo, it is totally different. You are supposed to be able to just slide everything forward about 2 inches.
Old Aug 13, 2017 | 06:26 AM
JoeM56's Avatar
JoeM56
Thanks for the utube hint, I was able to search for a video for the R56, found the Bentley book missed a very important step, removing the bumper carrier nuts. I'll let you know how that works out.
Old Aug 13, 2017 | 07:35 AM
Whine not Walnuts
Going to move this to the Gen2 area. I had to double check as I thought the original post was in the Gen1 area but I did not look at your signature.
