2006 Mini S Convertible electrical problems
Old Jul 27, 2017 | 10:14 AM
flyguy's Avatar
flyguy
So PLEASE help if you can. I have this 2006 S Model convertible and I had a problem with my power steering unit. My mechanic fix that problem but as soon as I get the car home I noticed now my air conditioner would not click on. So I call him and notified him he was going to see if he might have knocked off a wire. Well since then my wife took the car to a car wash to clean it. After that huge problems. The radio turns on and off by its self. Now the radio can be turned on with no key in the ignition. The wipers was turning on and off on their own. the entire air conditioning and heating panel wont turn on it just flickers with a hope of life. The seat belt lights on even tho all the seat belts are fasten. The windshield wash light flashes on and off even tho there is fluid in there.
I feel I am so screwed PLEASE HELP :(
Old Jul 27, 2017 | 10:38 AM
mdaz75's Avatar
mdaz75
First, welcome to the forum! I can turn on my radio with no key also, so, I'm pretty sure that's normal. As for the other stuff, you should start with testing your battery and alternator. These little guys are known for going batty when a new battery is due.
Old Jul 27, 2017 | 12:44 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Welcome to NAM.
First, how good are you with tools and electrical testers? If you are not confident then either you learn on your car, or, you take it to a shop. Next, an old battery will cause issue with the Mini as the control unit is so sophisticated that minor voltage changes cause problems. Do you have an S or a Justa? Last, suggest you take the car to a autoparts store and have them test your battery.
Old Jul 27, 2017 | 02:41 PM
Check the battery cable and the battery, when they change and fix the PS pump they come close to the battery and starter cables.
https://www.northamericanmotoring.co...mp-wiring.html
Old Jul 28, 2017 | 04:41 AM
JABowders's Avatar
JABowders
Veteran: Army
Wowsers! Sounds like something was not reconnected correctly, I would guess the engine ground cable was not grounded properly (PS Pump is electric) So prior to replacing the Battery should have been disconnected, and or the ground strap from the engine compartment should have been disconnected to isolate the electrical system during the service work.
Motor On!
Old Jul 28, 2017 | 06:22 AM
ItsmeWayne's Avatar
ItsmeWayne
There are many recalls for power steering on gen 1 Minis', you should see if your has one, if so, take it to a Mini dealer and the pump will be replaced and that may be the main problem. When the PS moter shorts out, it can cause havoc with your electrical system!
