Fuel Door Pin?
Fuel Door Pin?
I was at a MINI meet up this weekend and learned that my fuel door is suppose to lock when I lock my car. It's never done that, so I didn't know this was a missing feature. Anyway, it was pointed out that the pin that locks the fuel door is broken.
If I want to fix this, do I have to buy the whole Filler Flap Actuator? Is this the piece that is broken?
Thanks in advance.
Thanks in advance.
On my Gen1 vert, the pin system is separate from the cap section. It looks like a 6" long paper white out tool. You access by removing some plastic trim inside the trunk. You can also see it if you remove the tail light but you can not get the screws from the tail light area.
Thanks in advance.
Thanks in advance.
contact ALLMAGAutoParts on here.... i bought one off him at a very good price, and they give a 15% NAMotoring discount.
Right now we are out on the Clubman actuators. I see you found one on eBay, best of luck with the repair!
-Andrew
