Strange a/c problem
Old Jul 18, 2017 | 11:12 AM
Minyme1's Avatar
Minyme1
Strange a/c problem
My wife's 2008 r52 is having an a/c problem. If the temperature is 85 or less outside it seems to blow cold. Anything above 85 and it does not cool and the compressor clutch seems to be cycling more often. Every 10 seconds or so. Any suggestion as what to look for or check?
Old Jul 18, 2017 | 11:36 AM
Whine not Walnuts's Avatar
Whine not Walnuts
Moving you to the Stock Problems/Issues as your basic AC is no different than all the other Gen1 models.
If you have not already done so, I suggest you check out the second Sticky Thread at the Top of that section, Low Speed Fan Resistor. Also are you mechanically inclined as below is a good video on how a car AC works.
Old Jul 18, 2017 | 02:35 PM
Minyme1's Avatar
Minyme1
Fan comes on when a/c is turned on. I don't think that is the problem. I could be wrong.
Old Jul 18, 2017 | 02:48 PM
Whine not Walnuts
I suggest that the pressures be tested.
Old Jul 18, 2017 | 04:04 PM
Minyme1's Avatar
Minyme1
Will do that next. Will be next week as I have to go out of town in the morning. Thanks
Old Jul 21, 2017 | 12:26 PM
fourpaws's Avatar
fourpaws
You could be under or overcharged with freon. Have you had anyone add refrigerant lately?
There's a safety switch that will shut off the AC if the pressure gets too high or low. If you're overcharged, in hot weather your AC pressure will get too high. The safety switch will cut off your AC at that point. Then your pressure fallls back into the safe range and it turns back on. This is my best guess, but I don't know the exact design of the pressure cutout switch to give you better guess.
