MCS - Inlet Camshaft Sensor fault and rough idle?
Old Jul 13, 2017 | 01:32 PM
ChristianCam's Avatar
ChristianCam
Hi everyone, have a 2007 MCS N14 engine which generally drives and performs 100% apart from a very slight rough idle and an intermittant 2968 (P0341) Inlet camshaft position fault code. When I say intermitant, it can crop up within say 30 to 100 miles of driving after clearing. I've also noticed it backfires abit more than previous N14 engines I've driven and runs abit rich. Would this suggest timing? I've already replaced Vanos Solenoid, cat Sensors, cleaned the intake valves and serviced. Thanks in advance!
Old Jul 16, 2017 | 02:34 AM
JCdubGerm's Avatar
JCdubGerm
Definitely check timing.
Old Jul 16, 2017 | 06:43 AM
MiniToBe's Avatar
MiniToBe
how many miles? was the chain kit ever replaced? did you check the sensor itself if it's plugged right or faulty?
