F Model Wheel / Tire Options
Old Jul 12, 2017 | 07:19 PM
rtowell's Avatar
rtowell
I know this is not a new discussion, but the options change constantly. I have a 2017 F56 JCW with 17" Track Spoke wheels and the standard Pirelli run-flat tires.
I have added the NM 25 MM rear bar and CravenSpeed Big Pair and the result is that the stock configuration cannot keep up.
However, in the spirit of domestic bliss and improved performance, I am looking at three options:
1) Replace wheels and tires, but do I stay with 17s or move up to 18s
2) Replace the stock wheels with NM RESe05 and run the existing tires until they die
3) Keep the factory wheels and replace the tires with better rubber
Obviously Option 1 is the preferred options, but Options 2 & 3 are better from other perspectives.
Appreciate your views.
Old Jul 13, 2017 | 09:15 AM
DunkM's Avatar
DunkM
Stock runflat Tires are the weakest link. Whatever you do, replace them, or you will be unhappy with the results.
Old Jul 13, 2017 | 09:33 AM
iwashmycar's Avatar
iwashmycar
Look at weight too. HUGE improvements can be made. Like Dunk said, tires are #1, but even 'normal' tires will be an improvement based on weight alone.
If you get wheels, research weight too. Lighter the better. 18's could help as rubber weighs more than alloys usually. Finding a light 18 and good tires will be very beneficial.
Old Jul 13, 2017 | 01:02 PM
LormaD's Avatar
LormaD
Welcome tothe world of 18" RFT
I went with the free rubber to get the OEM JCW 18" wheels (the rims were not cheaper, than getting the Dealer Wheel and Tire Package, that come with RFT). I like the improved grip (over the 17" all season rubber, tenfold!!!).
But these damn RFT, or rather, todays rubber simply can't hold up to todays roads.
Frustrating. Took the dealer 48hrs to track a tire and get it installed (I have MINI Tire Care/Wheel)... At least it was Painless on the Wallet.
Old Jul 13, 2017 | 04:13 PM
rtowell's Avatar
rtowell
My experience with RFTs (two previous MINIs and a BMW X1) has been awful. Terrible ride quality, poor handling, easy to damage, hard to fix, and they're never in stock. I'm still amazed that BMW/MINI keep pushing them.
Old Jul 14, 2017 | 04:19 AM
02fanatic's Avatar
02fanatic
They keep pushing RFT's because there's no spare is my guess. I've never had them before so it's a new experience for me. I will probably kick myself when I finally go with regular tires at some point but I really have no real complaints for now overall. Only thing I've noticed is my summer Pirelli P7's can lose grip easily during spirited driving!
Old Jul 14, 2017 | 07:10 AM
LormaD's Avatar
LormaD
Prior to RFT
Before the advent of Run Flat Tires, BMW or Mercedes started this nonnsense* (or so I thought) of doing away with the spare tire. In the 1st generation of NO Spare On Board, there was a "Kit" supplied.
Basically the "Kit" involved a precharged can of tire sealant and inert gas. The gas to fill the tire up (in the case of a leak or flat) and the sealant as the stop gap to temporarily plug the leak. It still requires afterwards, to service the wheel and tire (needs to be washed and cleaned internally).
*nonsense= at first I thought so too, but really, for the masses, who is going to stop and change over there wheel and tire (the "lady" of your life, the senior 65 and over, or the middle of the night in rain or freezing weather etc..). So I get it, it makes sense.
NOT on a JCW though lol... I would of went with non RFT, and the tire kit.
Old Jul 14, 2017 | 08:36 AM
AliH's Avatar
AliH
I am in the same situation as the OP....But decided to keep the 17 OEMs and change the rubber. Anyone know if the OEM track wheel can accommodate wider tires? 215 versus 205? Thanks
Old Jul 14, 2017 | 03:12 PM
2017All4's Avatar
2017All4
Super Moderator
When I ordered my Clubman S All4, for $100 a spare with tool kit could be added, and the Clubman has plenty of room for a spare & kit in the rear lower compartment. Adds very little weight.
Within the first 1,000 miles my run flats were removed and bagged and stored in my garage, to be re-mounted on lease return in 3 years time.
The non run flats so improved the ride and handling it is just criminal that MINI makes motorers suffer -- it's just a shame that so many will never know the ride and handling that is possible with better rubber.
I know the issue for you JCW (non-Clubman) people is no space for a spare, so this complicates matters. But, FWIW, I'm glad I ditched the run flats, and my AAA card will allow me to stay out of the rain and away from weaving drunks looking to hit people changing tires on the side of the expressway.
In all fairness, the latest generation of run flats is better than what was available before. But run flat sidewalls are run flat sidewalls, and they do not optimize ride or handling, especially on lower profile tires.
Old Jul 14, 2017 | 04:24 PM
02fanatic's Avatar
02fanatic
If I ever take my JCW HT on an extended trip you can bet I will have the rear seats folded down & be equipped with my jack and spare wheel & tire, whether I'm running runflats or regular tires!
Old Jul 14, 2017 | 06:04 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
RF tires are very common in Europe. These are for the most part tailor fit to your model MINI and developed / tested on the Autobahn....and to some degree, is what gives the MINI the "train on rails" feel for the road.
Also, since they can be driven on, much safer than sitting at side of road, even if just waiting for AAA. Seen many Troopers even with lights flashing get rear-ended while parked....
Certain RF Tires are better than others, and for the most part like anything else, you get what you pay for. While the Pirelli's are cheapest of the bunch, ride is not as good, they tend to develop irregularities due to MINI's OEM camber settings and wear out much faster than the Conti's. Also, in wet weather driving, when Pirelli's lose grip in a turn, they will never regain traction until the vehicle comes to a complete stop against a guardrail or other hard object as if sliding on black ice....This has been true since making the P6 Model tire back in 1981.
Old Jul 17, 2017 | 06:49 PM
rtowell's Avatar
rtowell
Sorry, but not a fan of run-flats. My experience is that they are the most prone to failure and the least available for replacement. If you live in an urban area, I'm sure they provide a degree of security. Otherwise, they are substandard in every performance measure, they are difficult to source, and are very expensive. And ... there's a reason to like them?
Old Jul 18, 2017 | 06:06 PM
DunkM's Avatar
DunkM
At least in the US, in my opinion, it has far less to do with how a run flat naturally is, but rather how terrible most stock tires are. My thought is this, companies like the VW group have a huge number of very fuel efficient little engined cars to bring up gas mileage when they put nice Michelin of Bridgestone summer tires on their GTI, however, BMWs small engine fuel efficient car IS the MINI, meaning thin, low rolling resistance tires HAVE to come standard.
Old Jul 20, 2017 | 04:27 PM
rtowell's Avatar
rtowell
I ordered the Continental ExtremeContact Sport 215/45-17 and mounted them on the factory Track Spokes, fully expecting them to fit just fine. Guess what ... they rub against the front struts. It's not a hard rub as I can slip a few sheets of paper between the sidewall and the strut when it's sitting still, but it's close enough to rub when there is deflection.
So ... just to let everyone know ... not all 215s fit with no clearance issues ... MINI made the clearances pretty tight.
Old Jul 20, 2017 | 05:33 PM
02fanatic's Avatar
02fanatic
That sucks! It is true that fitment/clearance can depend on the chosen tire shape. Apparently your extreme contacts are just a bit too extreme! ;-). What are you going to do?
Old Jul 20, 2017 | 06:28 PM
rtowell's Avatar
rtowell
Ordered 10 mm spacers from ECS ... that should be more than enough to handle it.
The Continentals have a wider cross section than most of the other tires in that size, but not by much.
Old Jul 21, 2017 | 04:05 AM
02fanatic's Avatar
02fanatic
If the track spokes have an offset of 54 that would push out your wheel for an offset of about 44. You should be fine! It just sucks that the JCW wheels won't fit on a JCW lol! I see another set of wheels in your future!
Old Jul 21, 2017 | 09:46 AM
AliH's Avatar
AliH
I spoke to Tirerack yesterday about 225 for the OEM Track wheels and they told me that it will not fit for sure but that 215 is fine. I am glad you shared your experience....I guess I will need spacers.
Old Jul 21, 2017 | 03:20 PM
rtowell's Avatar
rtowell
That may not be true as the Continentals have a wider section width than some of the others. It is at 8.5". Some of the others are not so wide (8.3 - 8.4) and may work without spacers.
Old Jul 22, 2017 | 07:40 AM
AliH's Avatar
AliH
I was going for the Contis as well....But need to figure out spacers if I go that way. The other tires I am looking into Michelin Pilot Super Sport or Bridgestone S04 are 8.4". Not that big of difference given your information. They might require spacers as well.
Old Jul 22, 2017 | 01:20 PM
rtowell's Avatar
rtowell
ECS Tuning is a good source for spacers. They have quite a variety ... just check whether they are in stock before you order. The normally have that info on their site.
Old Jul 28, 2017 | 06:40 PM
rtowell's Avatar
rtowell
ECS spacers worked like a charm. I'm really pleased with the 215/45-17 with 10 mm spacers. It changes the look in a very subtle, but noticeable way. It's one of those things that would be hard to notice, but if you put two identical cars (one with the factory setup and one with the mod) it is evident immediately. Looks much more aggressive and now I like my black track spokes ... was not sure before. I'm really happy with the result ... just enough to make a difference, but not too much.
Old Jul 28, 2017 | 09:20 PM
AliH's Avatar
AliH
Can you share pictures of your car?
Would be great to see how it looks with 10mm...Pictures please!
Old Jul 29, 2017 | 11:23 AM
rtowell's Avatar
rtowell
Like I said, the change is very subtle but it is noteceable.
Old Jul 31, 2017 | 05:44 AM
Wow, that looks great!
