Shifter issue
Old Jul 10, 2017 | 11:41 AM
Craig Downey's Avatar
Craig Downey
Shifter issue
2003 mini auto trans shifter stuck in park, when key is on or running. Disconnect battery shifter moves with easy. Checked online tried everything I could nothing helped. Any help would be great
Thanks Craig
Old Jul 10, 2017 | 04:22 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Moving you to the Stock Problems/Issues area.
There is an interlock that must release when you disconnect the battery. You have R50 or a R53? How many miles on the car?
Old Jul 12, 2017 | 08:35 AM
Yes when you press down on the brake pedal it releases. Check the sensors near the brake pedal.
