Remote Central Locking
Old Jun 27, 2017 | 08:35 AM
bobleznw's Avatar
bobleznw
Final help for assistance if possible, I have R50 2004 Mini one and the car wont lock or unlock from the key. If I sit in the car I can lock and unlock it using the switch on the dash, it also locks when I drive off after around 5mph.
The receiver is behind the clock and it has three wires connecting it. I assume one is power the other maybe lock and unlock?
Anyone have a link which will tell me what the wires do?
Really getting annoying this is now!!
Thanks for your help
Bob
Old Jun 27, 2017 | 09:17 AM
Whine not Walnuts's Avatar
Whine not Walnuts
Moving this to the Stock Problems/Issues. If you have not already done so, have you searched that section for information?
Also, are you sure your key battery is still good?
Old Jun 27, 2017 | 11:41 AM
rkw's Avatar
rkw
They are power, ground, and a wire going to the body control module (probably digital communications).
Old Jun 27, 2017 | 11:48 AM
H_C's Avatar
H_C
Can you lock/unlock the doors inserting the key into the door?
If so, your key battery might be dead. You can buy a used key from eBay, replace the internals, and code the remote to your car.
Old Jun 27, 2017 | 12:06 PM
Whine not Walnuts
If the key is bad, replace the battery. I did a battery change about a month ago.
Old Nov 2, 2020 | 09:15 AM
MiniMacster's Avatar
MiniMacster
A question in addition to the above. My remote locking receiver seems to have failed. The range for picking up the key has reduced to having to hold the key a few inches in front of the windshield to get the car to lock and unlock. That is with a new battery in the key. If I replace the remote key receiver do I have to have it programmed, or is it simply an antenna that relays the key code to the body control module and work without any key programing?
Old Nov 2, 2020 | 09:38 AM
MVPeters's Avatar
MVPeters
There is a 'pairing' process sometimes needed after a key fob battery change, but it's not $$$dealer 'programming'.
