R55 Drivers side backuplight problem
Old Jun 20, 2017 | 11:59 AM
samakijoe's Avatar
samakijoe
I have a 2009 clubman
I am not getting power to this socket. Trying to find the fuse to just the drivers side. also do you have guide to the symbols on the inside fuse cover.
Joe D.
Old Jun 20, 2017 | 02:23 PM
mashby's Avatar
mashby
The reverse light only works on the passenger side. The driver's side is for a rear foglight if you have that option.
Old Jun 21, 2017 | 12:48 PM
samakijoe's Avatar
samakijoe
Thanks for the heads up on the backup light situation. But, I thought it's against the law to have a "white" light at the rear of the car while your going down the road. I bought the car used so I guess the PO chased the same problem for a while too and installed a white bulb.
So, do new cars coming off the line have a "yellow" bulb back there or is this (white bulb) legal back on the other side of the pond?
I'm thinking of rewiring the dead bulb to the other backup bulb so I will have two bulbs when backing out of my parking spot at Wally World..
Double your pleasure, double your fun.. As they use to say.
NB: Don't feel embarrassed if you need to ask what/who "Wally World" is..
Old Jun 21, 2017 | 04:40 PM
schatzy62's Avatar
schatzy62
It is illegal to have a while light at the rear while driving unless backing up. The left (drivers) side should have a red lens at the bottom and the right side should have a clear lens at the bottom.
if there is a while lens at the bottom on the left the lens was changed to a British/Japanese lens as they drive on the opposite side of the road so the reverse light and fog light are swapped.
No the fog light bulb is whilte but the lens is red as mentioned above
Somewhere here on NAM is a DIY on how to do that.
Old Jun 22, 2017 | 11:15 AM
+1 White clear lens light on the rear right, and rear fog light on the left. Rear fog light does not work unless activated or coded. This is for US or LHD clubmans.
We carry a Ziza backup light for the backup light now:
https://www.ecstuning.com/Search/SiteSearch/ES3209815/
samakijoe
Jun 20, 2017 11:50 AM
