JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW lowering spring on jcw
Old Jun 15, 2017 | 06:17 AM
Royis's Avatar
Royis
Hello I have a stock JCW and I want to lower it with H&R lowering spring. My question is do I need spacer if I stay with stock 17' wheels?
Old Jun 15, 2017 | 07:29 AM
subzero05's Avatar
subzero05
no you should be fine assuming you are looking at a minimal drop, say 1in F&R
Old Aug 12, 2017 | 03:55 PM
isamin's Avatar
isamin
The need for a spacer is determined by the offset of the wheel you are using.
Don't forget that these brakes are BIG up front.
With my choice of wheels I use a 12.5 spacer running 235/40 rubber and am dropped a full 2 inches.
ISAMIN
Old Aug 21, 2017 | 11:52 AM
RYANR56's Avatar
RYANR56
ISAMIN
I would love to see a picture of your car sitting that low! Is it flush? Must look awesome! My first car I bought was a 95 Honda accord. I had the very first set of 18 inch wheels made by racing hart. I had that thing slammed 3 inches down. My poor cat nearly got rubbed off on speed bumps. Not practical, but it looked cool! LOL
Old Aug 26, 2017 | 10:58 AM
Tigger2011's Avatar
Tigger2011
Alliance Member
H&R's are 1.4" drop IIRC. I went with Swift springs 1.1" in the front and 1.0" rear. Wheels are 7.5" wide with a 42mm offset and 235/40's. No spacers and clearance is not a problem. I did add lower cambers arms in the rear though so I could take some of the excess negative camber out.
Attached Thumbnails lowering spring on jcw-photo748.jpg   lowering spring on jcw-photo77.jpg
Old Aug 26, 2017 | 11:34 AM
RYANR56's Avatar
RYANR56
Looks awesome! Those are 235's? That is rad. I run 215/40on an 18 inch wheel. I have all the suspension in my signature that I am putting on Monday. I will see if I need Big spacers so I can run flash. There are some 5 mm spacers on it just because I had them laying around. But with a 75 mm stud bolt I have plenty of threads to push the wheels out. . I can't remember what the offset was of my wheel. My tires are new, but you have inspired me to look at a wider tires when I wear these ones out. Thanks again for sending the pic!
Old Aug 30, 2017 | 08:34 AM
KCLARK's Avatar
KCLARK
I know this may not be a direct comparison but I had H&R springs on an E46 M3, then changed to swift, and I cant tell you linear springs are the way to go. Those H&R will give you the slammed look but at the same time will be ALOT harsher than swift springs (something about them is more smooth feeling). Also heard good things about TSW which I think is also a linear springs. Im looking into doing springs for my JCW, but I suggest you consider linear over progressive rate springs!
