New F60 -- Lowered and rolling wide
Old Jun 13, 2017 | 08:16 AM
z_lacko's Avatar
z_lacko
Hey, folks.
I came from the WRX community and I probably see a dozen or so of those driving home everyday, so I wanted something more unique. Put a order in to the dealer in January and took delivery of my F60 Countryman in March. Been throwing wrenches at it since then because I can't leave things well enough alone and here we are.
After about 100 hours of build time, it's been lowered about 3" on coilovers with piecemeal components from F30 BMWs, Audi S3s and miscellaneous sourced components. There were a few custom machined pieces as well, such as the front camber plates (though E90 series mounts will work).
Fit 20x10 +35 Rotiform RSEs on it with a 255/35/20 Falken FK450 tire. Yes, there was a lot of cutting and grinding metal, liners and trim to get it to work.
Then painted miscellaneous components. Emblems. Grille trim. Headlight and taillight trim. Black gloss vinyl paint for all the plastic trim, save for the front grille.
To my knowledge, it may very well be the first F60 lowered on coilovers. I can't say that with any degree of accuracy, but I've not found any others stateside through social media or random forums.
A few photos are attached, but I'll be feeding more out through my Instagram and I can gladly take questions off the air. Kinda poor quality and a dirty car, but I have a more details to button up, then I'll take it out for proper photos soon.
Attached Thumbnails New F60 -- Lowered and rolling wide-mini-complete.jpg   New F60 -- Lowered and rolling wide-mini-rear-garage.jpg   New F60 -- Lowered and rolling wide-mini-front-fit.jpg   New F60 -- Lowered and rolling wide-mini-rear-fit.jpg
Old Jun 13, 2017 | 09:47 AM
B2FiNiTY's Avatar
B2FiNiTY
Looks amazing!
Definitely the first F60 I've seen lowered!
Old Jun 13, 2017 | 11:20 AM
Yes, possible. There is really nothing on the market aftermarket for the F60 yet. It shared some items from the F54 Clubman. Looks good.
**Update** Coilover options, watch for with /EDC/DDC and without EDC/DDC: https://www.ecstuning.com/Mini-2017-...ion/Coilovers/
Old Jun 14, 2017 | 07:51 AM
z_lacko's Avatar
z_lacko
Thanks, guys!
Yeah, I had hoped to find some more "stuff" for it out there since it's based off that BMW UKL platform that's the shared base with the F54. But even then, pickings were a bit slim save for universal kind of things like LCAs. I have to give a ton of credit to a friend who helped machine parts and source weirdo things.
Old Jun 14, 2017 | 06:34 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Welcome to NAM.
Old Jun 14, 2017 | 06:55 PM
MIminiclubman's Avatar
MIminiclubman
Welcome to NAM. Looks great. Lowering is not an option here in WI if you want to drive once the snow flies. My F60SE "Ethel" goes on the boat tomm. I have Falken's on my current R60 and they have been the best performing and wearing tire on a Mini for me.
Did you pull the rear lights to do the trim? Wondered if was similar process to R60.
Old Jun 14, 2017 | 08:37 PM
ItsmeWayne's Avatar
ItsmeWayne
Hi and welcome to the NAM family!
Old Jun 15, 2017 | 06:18 AM
z_lacko's Avatar
z_lacko
Thanks! Yeah, I retained all the OE suspension bits and cleaned them up to be put back on in November along with the OE wheels and snow tires. Not sure if we get as much snow as you all, but it can get hairy here in the mountains. I went into the project with the intent of fully swapping suspension seasonally.
The boat part is the longest wait. Stay strong! I know wear is going to be an issue for me with running so much negative camber, but I liked the look of the Falkens (previously ran PT722 on my old WRX) and I find they're generally economical, consistent in size and stretch okay. Sometimes with the cheaper stuff a tire will fit much smaller than the size suggests.
And yes, the rear tailights need pulled, but it's not a biggie. The biggest WTF I found was that they have two white half-moon things on the back that need to be spun around that holds the light in place. Access panel for those is in the trunk. Just spin those 180*, remove the black plastic panels the rear hatch seals against with a spirited yank (there are fragile clips close to the light) and drop the two 10mm nuts to pull the light. From there, there are only five or six clips that hold the trim ring to the lamp. I used a black two-part epoxy aersol spray primer, then a black two-part "Rat rod" black aerosol (should've used just a simple one part urethane, the rat rod black isn't jet black), then cleared with a two-part gloss aerosol. Hit the trim with some 320 grit sandpaper to etch it before priming, then wet sand with 600 after the primer and paint being careful not to burn through to the chrome again.
If you want to know how to take any other trim off, let me know -- I had everything but the roof bars and cockpit trim off.
Old Jun 18, 2017 | 05:17 AM
z_lacko's Avatar
z_lacko
I promised more photos once I was able to shoot them, so here they are:
Attached Thumbnails New F60 -- Lowered and rolling wide-mini-front-fitment.jpg   New F60 -- Lowered and rolling wide-mini-rear-shadow.jpg   New F60 -- Lowered and rolling wide-mini-moody-grill.jpg   New F60 -- Lowered and rolling wide-mini-street-view-slanted.jpg   New F60 -- Lowered and rolling wide-mini-against-hill.jpg
New F60 -- Lowered and rolling wide-mini-front-wheel-side.jpg   New F60 -- Lowered and rolling wide-mini-rear-wheel-side.jpg   New F60 -- Lowered and rolling wide-mini-side-profile.jpg   New F60 -- Lowered and rolling wide-rotiform-rse_.jpg   New F60 -- Lowered and rolling wide-mini-woodburn-2.jpg
Old Jun 18, 2017 | 05:54 AM
118's Avatar
118
That looks absolutely stunning!
Old Jun 19, 2017 | 08:15 AM
Well done.
Old Jun 19, 2017 | 11:24 AM
z_lacko's Avatar
z_lacko
Thanks so much for the compliments, folks!
Old Jun 20, 2017 | 07:48 AM
You are welcome.
Old Jun 20, 2017 | 08:08 AM
ProjectMini's Avatar
ProjectMini
Yeah baby YEAH!
Nice job Sr. Now don't forget to wave to your fellow MINI Fam!
Old Nov 25, 2017 | 12:03 PM
OJ MINI's Avatar
OJ MINI
Amazing, Amazing Amazing ����. Great work.
Old Nov 26, 2017 | 04:04 PM
AnOldBiker's Avatar
AnOldBiker
4th Gear - An Official NAM Greeter
and Welcome to the forum
Old Nov 26, 2017 | 04:24 PM
vetsvette's Avatar
vetsvette
Moderator
Looks really nice. Welcome.
Old Mar 21, 2018 | 06:41 AM
cmartyna's Avatar
cmartyna
I need to do this too!
I need to do something like this with my f60!!!
If you hear of any other places offering springs or kits,
post them up. Your MINI looks so good!
Originally Posted by z_lacko
hey, folks.
I came from the wrx community and i probably see a dozen or so of those driving home everyday, so i wanted something more unique. Put a order in to the dealer in january and took delivery of my f60 countryman in march. Been throwing wrenches at it since then because i can't leave things well enough alone and here we are.
After about 100 hours of build time, it's been lowered about 3" on coilovers with piecemeal components from f30 bmws, audi s3s and miscellaneous sourced components. There were a few custom machined pieces as well, such as the front camber plates (though e90 series mounts will work).
Fit 20x10 +35 rotiform rses on it with a 255/35/20 falken fk450 tire. Yes, there was a lot of cutting and grinding metal, liners and trim to get it to work.
To my knowledge, it may very well be the first f60 lowered on coilovers. I can't say that with any degree of accuracy, but i've not found any others stateside through social media or random forums.
A few photos are attached, but i'll be feeding more out through my instagram and i can gladly take questions off the air. Kinda poor quality and a dirty car, but i have a more details to button up, then i'll take it out for proper photos soon.
Old Jul 2, 2018 | 01:37 PM
Mister Spice's Avatar
Mister Spice
Great Eye you have!!!
Hey, folks.
I just received my triple black 2018 F60s (fwd) thanks for the info on yours , you and I are on the same track for looks on our F60. I had the same idea about mine... I already have 20" black 5 spoke American Racing wheels that came off my 2015 R61s …Im trying to find wheel adapters that will allow me to put them on this F60s. Dealer will lower mine they say.
Old Jul 5, 2018 | 08:25 AM
JABowders's Avatar
JABowders
Veteran: Army
Welcome.
That is a great looking car.
Motor On!
Mister Spice
131
Jan 18, 2023 09:13 AM
ayk07
Dec 28, 2021 08:12 AM
StanimalNSons
Feb 10, 2021 08:30 AM
MiniAdv
Dec 9, 2019 05:30 AM
Midnight Blue
Feb 21, 2017 04:48 PM
