Symptom: Overheating
Old Jun 12, 2017 | 12:25 PM
David E Holguin's Avatar
David E Holguin
So my R52 is fine when I am driving, but when I get to a light, the thermo-needle Max's Out. I ordered a new Thermostat, but was wondering if anyone has additional advice?
Old Jun 12, 2017 | 12:53 PM
Fly'n Brick's Avatar
Fly'n Brick
Water pump - water level - serpentine belt.
Old Jun 12, 2017 | 12:54 PM
David E Holguin
Thanks!
Old Jun 12, 2017 | 12:56 PM
Fly'n Brick
PS: The belt should be replaced about every 40K. Mine is due at next appointment in abt 120 miles.
Old Jun 12, 2017 | 01:11 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Moving this to the Stock Problems/Issues section.
You sure your fan is working? A recent posting about overheating turned out to be the fan motors not working.
Old Jun 12, 2017 | 01:47 PM
David E Holguin
Fan is working.....too hard in fact. LOL
Old Jun 12, 2017 | 05:13 PM
AoxoMoxoA's Avatar
AoxoMoxoA
Check coolant expansion tank and/or cap. If it's leaking or cap isn't holding pressure, you'll overheat.
Old Jun 12, 2017 | 08:03 PM
David E Holguin
Belt was already replaced....thanks to a brother on the board that suggested it when I was having other engine work done. Caps are all on tight.
Solution: I read online that I should bleed out the line at the Thermo Housing Bleed Screw, before invest a bunch of cash. I filled the radiator and tank with anti-freeze. Then unscrewed, slightly, while engine running, until steam and bubbles started. Had my son maintain revs to about 1700. Only Anti-Freeze started escaping, and the fan stopped. I have not had a single event with the gauge since.
Old Jun 12, 2017 | 10:12 PM
Fly'n Brick
Next thing consider strongly replacing the plastic expansion tank. They eventually split at the seam at inappropriate times. A stainless tank can be found on ebay and just move the cap over. Use a baster to remove the coolant then replace it after. A little coolant on the nipples makes it easy to slide the hoses back on.
