No Flow Radiator / Thermostat 2012 R56
Old Jun 12, 2017 | 08:12 AM
Snix_jcw's Avatar
Snix_jcw
I notice I have no flow of Coolant through my Radiator.
I have just replaced the rad, but it does not seem as if I'am getting any flow.
I think is happening is that the Thermostat is closed, and is not opening.
I took the thermostat off to inspect.
How can I trigger the Thermostat to open?
I have read about turning the AC on.
Even tried pouring boiling water onto the temp sensor, possibly I did not have the water hot enough.
I now read that it should open the circuit above 105° C
Nothing seems to open the Thermostat open.
Also reading around 11 Ohms on the Thermostat is that normal?
Any tricks?
Also I have read about a lot of these failing, how can one diagnose if that is in fact the issue?
Thank you
Old Jun 14, 2017 | 01:37 PM
Hairy W Bush's Avatar
Hairy W Bush
the only way I know is to bring the water up to that temperature. if it was your water pump, it would leak. it has to be that thermostat.
Old Jun 16, 2017 | 11:49 AM
Just getting the engine hot and to temp will open it up. Are you getting a CEL or do you have a code reader?
