Leaky thermostat housing permanent fix?
Old Jun 12, 2017 | 01:21 AM
Tonefiend's Avatar
Tonefiend
OK I bought my 2006 Cooper new and it now has 180,000 miles on it. It has definitely seen better days but it still going strong.
I had the thermostat housing replaced under warranty and I've done it myself two times after that. Well it's time to do it again...
Is there a permanent fix for this problem? I typically just get a new housing and gasket but I'm wondering if I should put some sealant on there or something? Anybody else have this chronic issue?
It seems like every couple months I'm doing brakes, tires, or the thermostat housing...
Old Jun 12, 2017 | 05:03 AM
Whine not Walnuts's Avatar
Whine not Walnuts
Couple of questions, first, you are cleaning the motor side that the gasket is placing against and second, are you torquing the bolts to the specified amount?
This is a justa?
Old Jun 12, 2017 | 07:59 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Shouldn't put any sealant on it. But also there was a few updates to the thermostat gasket. So we ONLY use the factory original MINI thermostat and gasket as they are the most reliable.
https://www.waymotorworks.com/thermo...t-r50-r53.html
And the new housing
https://www.waymotorworks.com/r53-th...t-housing.html
Old Jun 13, 2017 | 05:17 AM
Tonefiend's Avatar
Tonefiend
Yeah I'm cleaning the motor service off with acetone and a Scotch-Brite and torquing down to the required torque. My latest repair actually lasted longer than the dealers and the original factory installation.
thanks for the heads up, I will get the updated thermostat housing and gasket and see if that works. I hope the car has another 50,000 miles left in it!
Old Jun 19, 2017 | 05:42 PM
Cenla Mini's Avatar
Cenla Mini
I've changed mine twice now...once at about 30K and then again around 80K I think. It's got well over 130K now and still going strong...I keep watching it though and am ready to replace it when it goes bad.
