Coolant tank hoses (what size/diameter are they)
Old Jun 2, 2017 | 06:14 PM
MrMini819's Avatar
MrMini819
Hello everyone, new owner of a 2005 Cooper S.
I am going to be replacing my cracked/leaking plastic coolant tank with a new aluminum one. I have ordered the Forge replica that reuses a stock cap instead of the cheaper ones with the fixed non-pressurized cap.
I want to replace the 2 hoses that are attached to the coolant tank as mine are starting to get brittle/cracked. Can someone please tell me with 100% certainty what diameter/size the hoses circled in red within the pictures are (example: #1 3/16" and #2 5/8")?
My tank isn't set to arrive until late next week and I don't want to start disconnecting hoses now to find out their size. Would be nice to order everything in advance and have it ready to go when the tank arrives.
Also, I want to buy a new OEM/stock cap to fit on the new tank. Can someone please provide me with the correct cap or part number to buy?
Thanks in advance!
Attached Thumbnails Coolant tank hoses (what size/diameter are they)-mini-tank-plas.jpg   Coolant tank hoses (what size/diameter are they)-mini-tank.jpg
Old Jun 3, 2017 | 04:26 AM
Whine not Walnuts's Avatar
Whine not Walnuts
Suggest you take the tank to a local autoparts store and they will have the hoses that you need.
Old Jun 3, 2017 | 08:34 AM
MrMini819's Avatar
MrMini819
Thanks for responding. Yes, that would be the obvious thing to do.
I live within the outskirts of the city and we don't have any big parts stores such as Advance Auto and Pep Boys locally. The closest one is about 60-75 minutes away.
I was hoping that someone may of known the sizes or could've helped so that I could order the hoses on Amazon and have them shipped to me before the tank arrived. That way I don't have any down time on my car with lots of back/forth and running around to do.
Old Jun 3, 2017 | 08:54 AM
Whine not Walnuts
If you go to Amazon and type in Mini Cooper Coolant Hoses you well see all sorts of hoses and hose kits
Old Jun 3, 2017 | 08:57 AM
buzzsaw's Avatar
buzzsaw
I replaced the plastic coolant tank on our 06 R53 with the same metal tank that you ordered and I used the original oem hoses top and bottom and they fit perfectly. I also used the original clamps as recommended on this forum as they expand with the heat and do not bite into the hose as do often used aligator clamps. Getting the attaching bolts started and secured required my wife's smaller hands to negotiate the tight space and posed no difficulty for her. To check the fluid level, I made a dipstick out of a wooden dowel notched at two inches for half full, which was a recommended level. Works great. It's an easy diy(youtube). It has been sixteen months since the installation and all is well. Good luck.
Old Jun 3, 2017 | 01:15 PM
Guke's Avatar
Guke
I found a diagram of the coolant tank set up with the part numbers for the hoses on Real OEM.
They do not specify the dimensions. But here is the link to the diagram, and the OEM replacements from pelican parts.
https://www.realoem.com/bmw/enUS/sho...diagId=17_0236
http://www.pelicanparts.com/cgi-bin/...on=17127518581
http://www.pelicanparts.com/cgi-bin/...%0917127518577
