R56 N12 Engine 2008 Mini Cooper Oil Pan Gasket
Old May 26, 2017 | 07:49 PM
Rob Rush's Avatar
Rob Rush
Trying to replace my oil pan gasket and getting a little confused because autozone has two very different shaped ones listed. My Mini engine is N12, its an R56 2008 coop with sport mode.
Anyone here know for certain which gasket shape i get?
Old May 26, 2017 | 07:50 PM
Rob Rush's Avatar
Rob Rush
these are the two shapes
Old May 26, 2017 | 07:51 PM
Rob Rush's Avatar
Rob Rush
VIN Info
Old May 26, 2017 | 10:11 PM
Scooter24's Avatar
Scooter24
I went to ecs tuning and put your car in (it's a base and not the s correct?) As base, and it shows a gasket the looks identical to AutoZone os30820 gasket.
Old May 26, 2017 | 10:16 PM
Rob Rush's Avatar
Rob Rush
yep, the base, thanks a lot mate
Old May 26, 2017 | 10:29 PM
Scooter24's Avatar
Scooter24
I'm not sure if the pic you posted was from Autozone's website, It just looked like it when I glanced at it. Either way the gasket looks like the gasket in your pic with os30820 part number.
Old May 27, 2017 | 01:37 PM
oldbrokenwind's Avatar
oldbrokenwind
N14 doesn't use a gasket anymore, it was switched to "gasket-in-a-tube". Maybe the same will work for the N12?
Old May 28, 2017 | 03:30 PM
sikamini's Avatar
sikamini
I used this, the last time I had the oil pan off on my N14.
Old May 30, 2017 | 11:12 AM
Yes its here:
https://www.ecstuning.com/Mini-2008-Cooper-R56-Base-Coupe-L4_1.6L_N12B16A/Engine/Gaskets_-and-_Seals/2
MINI went with a sealant (83190404517) for all the N12, N14, N16, and N18 engine oil pans. But some people like and prefer the normal gasket. (11137565928)
https://www.northamericanmotoring.co...an-gasket.html
