Easy way to shut bypass valve/zip tie shut
Old May 16, 2017 | 07:32 PM
austin5's Avatar
austin5
What's the easiest way to close up the bypass valve? I'm not super mechanically inclined but have power loss across the board and my mechanic has found nothing wrong.
Im at 2psi max boost in a 17% pulley car, here's to hoping it's just the bypass valve!
Would like to zip tie it shut to test, but would also like to not have to take it out if I don't have to.
Old May 17, 2017 | 07:06 AM
nshannon29's Avatar
nshannon29
If you reach down behind the right intercooler horn you can reach the bypass valve. You can zip tie the actuator arm closed and wrap the zip tie around the adjustment screw to the right of it. It's a tight fit to do it from above but it can be done.
Old May 17, 2017 | 05:31 PM
Eric_Rowland's Avatar
Eric_Rowland
If you have 2psi boost max, I wouldn't think the BPV would be the issue, unless it's not closing fully, in which case manually closing it wouldn't change the result.
Old May 18, 2017 | 05:21 AM
austin5's Avatar
austin5
After pressing the lever I'm not hearing any clicking on release, so it may not be closing all the way, looks like I'll take it out and hopefully a Detroit tuned one will take care of the issue.
Old May 18, 2017 | 10:39 AM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
We see these break all the time. Like said above, with the car off you thread a zip tie around the arm and the set screw and tighten it up. a long pair of pliers is helpful. this trick always rules out or shows the fix instantly. Let us know if we can help!
Chad
Detroit Tuned
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Old Jun 10, 2019 | 08:09 PM
A383Wing's Avatar
A383Wing
Chad
Detroit Tuned
I'm going to try this with my '06 R52 JCW car this week..... the car falls on its face when accelerating.... I just wanted to close the valve for testing before my new valve arrived
Bryan
Old Jun 12, 2019 | 02:41 PM
A383Wing's Avatar
A383Wing
I zip-tied the valve closed, car still falls on its face when accelerating, I don't think the valve is my problem now
Bryan ( time for plan B)
