Head Gasket Replacement Analysis (pictures of gasket/block/head)
Old May 13, 2017 | 04:06 PM
CSP's Avatar
CSP
Hi all. Does anybody have any opinion on these? Anything stand out to anybody as majorly wrong?
Attached Thumbnails Head Gasket Replacement Analysis (pictures of gasket/block/head)-img_1644.jpg   Head Gasket Replacement Analysis (pictures of gasket/block/head)-img_1645.jpg   Head Gasket Replacement Analysis (pictures of gasket/block/head)-img_1646.jpg   Head Gasket Replacement Analysis (pictures of gasket/block/head)-img_1647.jpg   Head Gasket Replacement Analysis (pictures of gasket/block/head)-img_1648.jpg
Old May 13, 2017 | 05:10 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Going to move this to the Problems/Issues folder.
I did not see anything that jumped out a me. Why did you remove? It appears on the 2nd picture, that the second cylinder from the right may have been leaking? Did you have any chocolate milkshake goo in the valve cover?
Modmini has a youtube vid on replacing the head gasket. Do you have straight edge to check if the heads are warped? He uses a Painters Guide to check.
Old May 14, 2017 | 08:44 AM
50pascals's Avatar
50pascals
Without having the parts in hand.....It looks like the Cylinder #1(?) Next to the timing chain had a coolant leak based on the deposits on the valves and the track through the compression ring contact. But I do not see the same track on your gasket pictures.
What do the exhaust ports look like? The cylinder with the coolant leak will have clean exhaust ports.
It looks like this port on the header is cleaner than the others.
Old May 14, 2017 | 09:14 AM
AoxoMoxoA's Avatar
AoxoMoxoA
Not completely sure of the precise point of head gasket failure, but I did notice what appears to be a crack in the head at the cylinder #1 spark plug location.
Old May 14, 2017 | 07:40 PM
JaimeS's Avatar
JaimeS
Wow great catch!
Old May 15, 2017 | 09:47 AM
CSP's Avatar
CSP
So I wasn't happy with how exhaust valves in cylinder 1 looked so I ordered another. In the down time, I figured I should take it to a shop and have them inspect it. So it's going to a local shop tonight.
Thanks for the tow. Removed due to coolant in cylinder 1. knew I had an oil leak into cylinder 1, too. I should've checked the rest of the cylinders for coolant before I ripped it apart but I didn't :/
I used a straight edge and it looked fine to me, but, as I said above, it's going to a shop for inspection. Took the head off with the help of modmini's video. <3 his stuff.
Cyl 1 definitely had a leak. I didn't pay attention to the exhaust ports. I'll have a look when I get home.
You... Simultaneously ruined my week and completely made me happy that I decided not to just put everything back together. MFer, though. I really hope that can be welded. How did I not see that when I was looking in person at it? You're the man, though.
Originally Posted by JaimeS
Wow great catch!
Indeed.
Old May 15, 2017 | 11:36 AM
AoxoMoxoA's Avatar
AoxoMoxoA
Sorry, and happy I could be of assistance...
Not sure of the process and/or success rate of welding an aluminum head...
Thanks, and you're welcome... I think...
