Fuel Gauge won't go lower than 1/4 tank
Old May 12, 2017 | 11:07 AM
ST3ALTHPSYCH0's Avatar
ST3ALTHPSYCH0
So one issue that I've had w/ my R50 is that the fuel gauge works fine until 1/4 tank and then it won't go any lower (except when the car is off.... so I know there's no physical obstruction in the cluster). I ran out of fuel on my way home when I bought it, b/c I didn't know how to cycle through the OBC yet, and thought I had 1/4 tank left.
I'm going to try an ECU reset, but I don't think that will help. Do you guys think there might be an obstruction around the float not letting it drop further than 1/4 tank? How would I check for that?
Old May 12, 2017 | 03:56 PM
ST3ALTHPSYCH0
So... ECU reset SEEMS to have cured it. I went through the diag menus, and have 2 good sending units. After the reset, the red light indicating < 2.5 gal fuel was illuminated for the first time since I've bought the car. As an added bonus, my trip to the fuel station also gave me my first >30 mpg reading on the OBC. Maybe I've gained a couple MPG in the process too!!
Old May 12, 2017 | 05:35 PM
coopermike29's Avatar
coopermike29
looks like you fixed it !!!!
Good Work !!
And thanks for sharing!!
Old May 12, 2017 | 08:28 PM
pkunk's Avatar
pkunk
Can you explain how you did that? My gauge does the same thing.
Old May 13, 2017 | 05:21 AM
ST3ALTHPSYCH0
Good Work !!
I wanted to be sure that anyone stumbling into my thread in the future wouldn't end up in this situation.
http://new.minimania.com/ECU_Reset_P...50_52_53_MINIs There are also threads here on NAM explaining and on mini2 and on ****************.
Old May 13, 2017 | 08:17 AM
pkunk's Avatar
pkunk
Thanks,
I'll keep looking but can't find it for my 2008 R55
Old May 13, 2017 | 07:30 PM
ST3ALTHPSYCH0
Thanks,
Ah, I didn't realize that you had a 2nd gen.
