Interior/Exterior Xenon Headlights for MCS 04
Old Oct 4, 2004 | 01:13 AM
mytaimymini's Avatar
mytaimymini
Dear thankful y'll,
My MCS 04 do not have Xenon Headlights. Could I separately buy and install them aftermarket? I asked the dealer that they said " NO, they are only come from factory" Also the foglights is costing me $1000 to install them up :-(
I've just purchased 04 mini cooper S model in the late of June. Luckily I didn't have to wait for 10 months waiting list because there was a wanna be my mini available at the moment so I bought. Anyway, the car came with only Premium package and what I need was to add Sport package so they couldn't. Any idea to get my car install xenon headlights? would that be awesome to get those 04 or even 05 xenon headlights put on my car?. HELP me please.
Thanks.
Tai
Old Oct 4, 2004 | 01:17 AM
MINIclo's Avatar
MINIclo
7th Gear Gal
Hi Tai,
I'm going to delete the posts you made about Xenons in TheOfficeMaven's sunroof flag thread.
Here's a link you might want to look at:
https://www.northamericanmotoring.co...non+Headlights
Clover
Old Oct 4, 2004 | 02:46 PM
JoeDentist's Avatar
JoeDentist
Motoringfile.com saya that the lights are retrofittable and Mini has a kit to do so. Price is probably an issue, though.
Old Oct 4, 2004 | 03:11 PM
meanboy's Avatar
meanboy
If there is a retrofit kit then you could just look for the used xenon headlights and ballasts. It's two screws or something like that to remove from the bonnet. I saw a set advertised locally a while back and the seller was asking $250 for both sides complete. You should be able to do the same or you could cruise the wrecking yards over the internet and you might get lucky.
Old Oct 4, 2004 | 10:38 PM
mytaimymini
Thank you very much Meanboy I'll follow your suggestion :-) thanks to you all.
Old Oct 4, 2004 | 11:05 PM
meanboy's Avatar
meanboy
found those on the internet
a quick search found the lh side..not sure of the price.
2002
Headlight Assembly
BMW Mini Cooperw/Xenon, LH- CK COND. S3B024$CallLKQ - Lakenor Auto Salvage USA-CA(Sante-Fe Springs) E-mail 1-800-525-36672002
Headlight Assembly
BMW Mini Cooperw/Xenon, LH- S3B027$CallLKQ - Lakenor Auto Salvage USA-CA(Sante-Fe Springs) E-mail 1-800-525-3667
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Old Oct 4, 2004 | 11:14 PM
mytaimymini
Hi Meanboy,
This is very helpful. Thank you soooo much!! I will try to call them tomorrow and will let you know :-)
Thanks again,
Tai
Old Oct 4, 2004 | 11:36 PM
meanboy's Avatar
meanboy
Send an e-mail to the fellow on ebay to see if the headlights are complete and then call the mini parts guy and see what is needed to get your car headlights retrofited. Maybe, someone local with xenons can pop open the bonnet and you can compare yours with his/hers.
Good luck!
Old Oct 5, 2004 | 10:12 AM
KatanaPilot's Avatar
KatanaPilot
the headlight retrofit kit mentioned in motoringfile is for retrofitting 05 headlights onto earlier cars. It said nothing about retrofitting xenons to non-xenon cars.
To make xenon lights fully functional, you will also need level sensors on your strut, headlight washer tank, plumbing, and associated wiring. Finally you will also need your dealer to re-code it. It is doable, but it is not a simple job, and it may be cost prohibitive.
Old Oct 5, 2004 | 10:21 AM
meanboy's Avatar
meanboy
Are the washers for the headlights necessary? What would the dealer need to recode?
Old Oct 5, 2004 | 12:00 PM
mytaimymini
Bad news guys, I spoke with one the tech guys in LongBeach MINI where I bought my MCS so he says that either me or the dealter can't do that considering modification. He said after market--maybe they'll do though--for some reason I don't want to do it after market which it will cause the warantee. Well, I guess I'm going to use my non-xenon :-) which I'm not happy about it :-(
Thank you all you guys very much :smile:
Tai
Old Oct 5, 2004 | 12:16 PM
meanboy's Avatar
meanboy
Looks like it's involved..found a nice post on bimmerforums.
http://forums.bimmerforums.com/forum...32#post2074732
Old Nov 17, 2004 | 12:13 PM
mytaimymini
Hi all :-)
Back again with very needy your opinions;
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=42606&item=4505131 090&rd=1[/size][/font]
http://outmotoring.com/philips_blue_vision_bulbs.html
Which one is better in your opinion? Thanks to you all.
Tai
Last edited by mytaimymini; Nov 17, 2004 at 12:25 PM. Reason: this is better! sorry!
Old Nov 17, 2004 | 04:08 PM
apexer's Avatar
apexer
I'd go with the 4000k bulbs. The 8000K are a deeper blue but, will not project out as far as the 4000 bulbs. Bottom line, do you want to look cool or, beable to see where your going.
Old Nov 19, 2004 | 12:48 PM
dcsmd007's Avatar
dcsmd007
Coordinator :: PDX MINI
If there's a will, there's a way!
Here's a picture of ballast for aftermarket HID.
Old Nov 19, 2004 | 01:11 PM
mytaimymini
nice job dcsmod007. Where did you get those from? how much are those? if I may ask which after market shop did you use?
Also, questions!, if I had a used xenon headlights from MCS 04 installled on my non-xenon headlights which I don't care with self-leveling and the washers. Can I do that? I live in LongBeach LA, Ca. Which shop would you prefer? that also causes the warrantee from the MINI? I'm so dump with these things Any idea guys?
Big thank you to you all.
Taktai
P.S. Is Steve's auto clinic in LA good?
Old Nov 20, 2004 | 07:08 PM
JoeDentist's Avatar
JoeDentist
Dealers are always going to say that things can't be done. I bet if you were to find a wrecked MC or MCS with xenonsthat had been hit from behind (depending on what model you have), and just take the entire hood assembly and switch it with your car, it would not be all that complicated to hook up the washer reservoir or reprogram the computer. The trick, as always, is finding the parts in an affordable manner.
Old Dec 8, 2004 | 12:34 PM
mytaimymini
I now have a pair of 04 xenon headlights :smile: so what I should do next? I'd appreciate with all ideas and opinions
Thank you much
Taktai
Old Dec 9, 2004 | 04:12 PM
JoeDentist's Avatar
JoeDentist
First thing I would do is get an electrical manual that shows the wiring diagram for the car. I assume that the headlight uckets are a simple switch out. Its actually the washers that are the big deal to install, since this requires a hose, reservoir, and a second electrical connection. You should obviously try to get the lights working first, then tackle the washers. Find someone with Xenons that were factory installed and take some pictures of how they are connected with a digital camera for reference. I would not be shocked if when you exchange the buckets, it is a simple plug-in to get the light part working.
Old Dec 10, 2004 | 08:05 AM
UB's Avatar
UB
Hi there, I would really love to know which aftermarket HID kit u r using? and if u had to do any modifications to get the HID bulb to fit?
I hear HID bulbs are too long to fit in the halogen light housing, there is a cap inside that blocks its path
Dec 23, 2015 10:36 AM
Bennyboy
Aug 18, 2015 07:28 AM
dyeLucky
Aug 7, 2015 07:10 AM
