Any idea what's wrong?
Old May 5, 2017 | 07:02 AM
Truffle's Avatar
Truffle
My mini is running rough. Seems to idle higher then normal and under any sort of moderate acceracation, it spudders/backfires like crazy and acts like it wants to die almost. Check engine light is on. Did an oil change almost 2 weeks ago and also replaced the stock resonator on the discharge pipe with one from WMW. Any suggestions what is wrong or where to start looking at? :(
Old May 5, 2017 | 07:34 AM
R56in's Avatar
R56in
First thing to do is to get an OBD2 code reader if you can. That will read out the check engine light codes so you can better pin down the problem. Without knowing the error codes, its just a guessing game.
Old May 5, 2017 | 07:41 AM
DneprDave's Avatar
DneprDave
I agree, an OBD2 reader is the most important tool you could get for your MINI.
There is no excuse not to have one, they are not expensive.
Old May 5, 2017 | 07:43 AM
Truffle's Avatar
Truffle
Will any auto parts store check for codes?
Old May 5, 2017 | 08:15 AM
DneprDave's Avatar
DneprDave
Autozone will, I'm not sure which others do.
Old May 13, 2017 | 12:29 PM
Truffle's Avatar
Truffle
Mini still is not running right. Changed the spark plugs and cleaned the charge packs. I don't know if its just bad gas and new gas hasn't filter through yet. Filled tank with fresh gas yesterday. Here are the codes thrown. Haven't seen these code numbers with like the E's and F's. I know the pictures aren't the best quality.
Old May 22, 2017 | 06:16 AM
MiniToBe's Avatar
MiniToBe
clear the codes and see if they return...if so, swap fuel injectors and see if the codes follow.
