Navigation & Audio Working on a friends Mini
Old May 1, 2017 | 07:39 AM
Andrew Mack's Avatar
Andrew Mack
I am currently doing a small stereo upgrade for a close friend. Joined to ask about the front speaker impedances on a 2012 CM non HK. He does not want to upgrade the head unit or add an amp for mids/highs so I am looking for a budget friendly speaker swap for it.
Old May 1, 2017 | 07:47 AM
Andrew Mack
Sorry I didn't clarify, Looking to upgrade only the front speaker/tweeters.
Old May 1, 2017 | 08:32 AM
rebonz's Avatar
rebonz
You may want to check out BAV sound. They make a drop in that definitely improves the sound. They incorporate a mid driver and point source tweeter together.
Old May 1, 2017 | 09:42 AM
Andrew Mack
I really wouldn't consider 300 budget lol. I just need to find out the Impedance so I can piece together a decent 3'' full range and midbass.
Old May 1, 2017 | 10:10 AM
Whine not Walnuts's Avatar
Whine not Walnuts
I'm moving this the Gen2 Radio/Nav folder. If you have not already done so may I suggest that you check out the that folder as there are over 1,600 threads on radios and nav systems there. You may find what you are looking for.
And, welcome to NAM.
Old May 1, 2017 | 10:13 AM
Andrew Mack
I did a search and found most of my questions, minus the impedance one.
Old May 1, 2017 | 10:40 AM
Andrew Mack
Is there going to be a difference in the R60 as far as impedance, and doing the front/rear swap for the speaker inputs?
Old May 1, 2017 | 11:09 AM
DneprDave's Avatar
DneprDave
Just measure the old speakers. You can use a multimeter to estimate the impedance.
Typically, the resistance reading should be roughly 15% less than the nominal impedance on the label. For example, it's normal for an 8-ohm speaker to have a resistance between 6 or 7 ohms.
The majority of loudspeakers have a nominal impedance of 4, 8, or 16 ohms. Unless you get a strange result, it's safe to assume your speaker has one of these impedance values for the purpose of pairing it with an amplifier.
Old May 1, 2017 | 11:10 AM
rebonz's Avatar
rebonz
Stock midrange drivers in my 2013 are labeled 4 ohm
Old May 1, 2017 | 05:56 PM
Andrew Mack
Looks like his front doors only have one 4" full range. Does anyone know if this model has the front and rear that should be swapped? Trying to figure out if I should tap into the front or rear for the LC2I.
Old May 4, 2017 | 05:56 PM
Andrew Mack
Bump.starting install tomorrow
Old May 8, 2017 | 04:25 AM
James3370's Avatar
James3370
I have a 2012 that I installed some inexpensive speakers in the doors for awhile before doing my full stereo install.
For the lower part of the door, I used Rockford Fosgate R165X3 3-way 6.5" coaxials.
For the upper "pods", I used Rockford Fosgate R14X2 4" 2-ways. I used (3) of the tabs on the speaker & just bent the 4th one into the surround near the door handle arm....if that makes sense.
Both sounded pretty good (& ALOT better than stock), but I've since taken everything out & done a full system install :D
My install thread - https://www.northamericanmotoring.co...o-install.html
btw....to answer your original question, if you look at my install thread....post #5...the pic shows the factory speaker & it says "4 ohm" ;-)
Old May 8, 2017 | 11:46 AM
Andrew Mack
That's the issue with his car. It only has one small speaker in the door. So I'm trying to figure out where the speaker wires are and color without tearing the door panels and speakers off.
Old May 8, 2017 | 11:59 AM
James3370's Avatar
James3370
I found the color scheme in this thread.....I've since deleted it off the iphone "note" I made, but it's in here (somewhere LOL)
https://www.northamericanmotoring.co...nt-how-to.html
Old May 8, 2017 | 12:02 PM
James3370's Avatar
James3370
think it was this post?
https://www.northamericanmotoring.co...ml#post1577303
Old May 8, 2017 | 12:24 PM
Andrew Mack
Does the R56 and R60 have the same wiring?
