Loosened motor mounts, motor won't raise
Old Apr 20, 2017 | 06:25 AM
Thumper Simpson's Avatar
Thumper Simpson
Loosened right and left top motor mounts, removed bottom motor mount bolt, need 1/2" of raising but motor and tranny won't budge. What did I miss?
Old Apr 20, 2017 | 06:37 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Does it even rotate any ? Just removing the lower mount it should at least rock some....
Old Apr 20, 2017 | 06:40 AM
-=gRaY rAvEn=-
Moderator
Guessing your installing a SC pulley in an R53 ?
This guy is really good...
Old Apr 20, 2017 | 06:45 AM
Thumper Simpson
Doesn't move at all. need 1/2" lift to clear CVT tranny pan. Not an S. Replacing CVT filter ad fluid.
Old Apr 20, 2017 | 07:05 AM
Thumper Simpson
I let it set with pressure under the motor with a jack and it crept up enough to clear the pan. Now I have to decide whether to re-use the synthetic pan gasket or use the new aftermarket cork gasket.
Old Apr 20, 2017 | 07:06 AM
Thumper Simpson
pan was clean. Haven't opened filter yet. 134,000 miles.
Old Apr 20, 2017 | 02:05 PM
Thumper Simpson
Can't get drain plug out of pan. Need freeze spray, but no electronic suppy stores around.
