Suspension How difficult are coilovers to install?
Old Apr 4, 2017 | 06:54 PM
minihoon's Avatar
minihoon
I am pretty set on ordering race land coilovers for my 05 cooper s. However im a total noob at working on cars(it's my first car). My friend intends to help me install the coilovers, but he also has little experience with this. So my question is how difficult will coilovers be to install between two noobs? Or would i be better off bringing it to a shop as all i have done so far to the car is put on new wheels(esm 007). Tools shouldn't be a problem i'll buy whatever i don't have.
Old Apr 4, 2017 | 09:48 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Overview of process http://www.meganracing.com/tech/inst...l%20coil-overs
I don't consider it noob territory.
Old Apr 5, 2017 | 12:45 AM
808R53's Avatar
808R53
Utube
Old Apr 6, 2017 | 10:36 AM
Gitmoe's Avatar
Gitmoe
Coilovers aren't that bad. I've done them on several cars. I'll be doing my R53 soon finally. You'll want one of these... https://www.ecstuning.com/b-genuine-...300491931~oem/
The upper front strut nut is weird on the MINI. It's the first time I've ever needed a special tool to do a coilover install. The danger is the compression bolt in the front knuckle. If you break that head off you're pretty screwed. I've heard they can be tight and a pain to get loose.
Old Apr 6, 2017 | 10:56 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
pretty easy, a little more tricky if you do alignments yourself
Old Apr 6, 2017 | 11:22 AM
gumbedamit's Avatar
gumbedamit
The "Pinch Bolt"?
If that is what you are talking about , YES, if you break the head off that bolt, you are screwed....I broke mine off replacing my struts, had to get another knuckle after spending too much time trying to drill it out when I could have just spent $40 and 30 mins getting another knuckle. Make sure you spray tons of penetrating oil before attempting. A impact wrench is your BEST friend....
Old Apr 6, 2017 | 01:52 PM
Guke's Avatar
Guke
Originally Posted by gumbedamit
The "Pinch Bolt"?
I can also confirm this. Broke the head off of BOTH pinch bolts. Took surprisingly little force with a breaker bar. I sprayed penetrating oil and everything. It feels like its coming out then POP!... luckily I was already replacing the knuckles, ball joints and wheel bearings and installing coilovers.
Old Apr 7, 2017 | 06:22 PM
Chris Fit Taylor's Avatar
Chris Fit Taylor
Super easy
My brother and I worked on my R53 last August. Purchased some Megan euro street II from ECS Tuning and we installed everything in front of the house WITHOUT power tools in 1.5hours. He did the back I did the front. Then used Groupon to get a $50 alignment from sears. Haha 😂🤣😭
