Reservoir hose rubbing
Old Mar 25, 2017 | 06:59 AM
Lamar Raybon's Avatar
Lamar Raybon
I have a 09 jcw and the issue I'm having is my reservoir hose seems to rub to the point of a coolant leak when shifting gears. Is there a fix for this? Doesn't seem like it's a motor mount issue.
Old Mar 25, 2017 | 10:10 AM
oldbrokenwind's Avatar
oldbrokenwind
It could also be the "flex-joint" connection at the reservoir. However, if you've already determined that the hose is interfering with linkage, a tie-wrap or two would be an easy fix --- replace the leaky hose and relocate the interfering part.
Bean0709
Mar 24, 2017 06:01 AM
