Webb Motorsports Camber Plates now available!
Old Sep 27, 2004 | 03:37 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
!PICTURES! Webb Motorsports Camber Plates now available!
Here they are! These are the end all in camber plates. The units are easily adjustable and give the largest range available of the plates I have tested to date (which includes basically everything on the market). They allow for known settings to be marked on the existing indexes for quick camber changes (like at the track). The units come with stock marked as a slightly taller index, with .5 degree range marks from +.5 to -3.0. We used a teflon lined Aurora monoball to avoid bearing failure issues, and mount it in a stainless steel carrier, which makes this unit the strongest on the market. The top piece is anodized aluminum, complete with lightening holes to reduce as much weight as possible. These units are mounted under the strut top in the chassis, making the chassis the load bearing piece rather than a few bolts. They are also VERY competitively priced. Any strut brace that works with the stock set up works with the Webb Motorsports camber plates, as will any spring perch or coilover rebound adjustment.
These are now available for immediate shipping at $495.
vetsvette
Oct 20, 2015 07:42 AM
got_mini?
Oct 7, 2015 02:12 PM
Oct 1, 2015 12:34 PM
Oct 1, 2015 12:13 PM
