R57 added LED lightbar to front grill
Old Mar 10, 2017 | 03:01 PM
floydturbo's Avatar
floydturbo
I added a Rigid Industries LED lightbar to my front grill and wired it to come on with the high beams. I used a Fein oscillating saw to cut the plastic grill and used the taller metal mounts turned sideways to attach it to the grill.
Attached Thumbnails added LED lightbar to front grill-screen-shot-2017-03-10-at-2.57.00-pm.png   added LED lightbar to front grill-img_4944.jpg   added LED lightbar to front grill-img_4945.jpg   added LED lightbar to front grill-img_4946.jpg
Old Feb 22, 2018 | 07:31 PM
cmdycrzr's Avatar
cmdycrzr
Installation
How big a deal was it to do this? I would actually have the dealer install it as I am a mechanical idiot. Is it that much of an improvement?
Old Feb 22, 2018 | 08:13 PM
cornjuice's Avatar
cornjuice
any idea of Lumen output ?
Old Feb 23, 2018 | 06:32 AM
floydturbo's Avatar
floydturbo
Awesome high beams
it makes a massive improvement to the high beams. The model is Rigid Industries 91061 SR-Series.
Old May 6, 2019 | 09:42 PM
IsaacinPhilly's Avatar
IsaacinPhilly
This is exactly what I'd like to do except I'm hiding it behind the grill.
Can you explain the wiring? Does power come from headlights or direct from battery? I test wired my light bar with power from the battery today and I fried my FRM which is now being replaced for something like $600.
Howdoes it only come on with high beams? Any chance of pictures of the wiring?
Old May 7, 2019 | 07:49 AM
I like mini clubman's's Avatar
nice clean installation. Good job
Old May 7, 2019 | 07:59 AM
Capt_bj's Avatar
Capt_bj
basic wiring for 'added' lights
notes:
1. picture implies everything runs to one SAME ground. In a car, the chassis is the ground so the physical location doesn't matter, so long as you are at a ground - typically bare metal body work.
2. this shows a simple manual toggle switch but you can make this something else. Make it the high beam trigger and they come on with high beams. Use the HB trigger AND a switch and they can come on only with the BH. Make it a line to fog light power and same effect but with the fogs.
3. Want to add air horns .... same basic layout ... a power wire to one of the horns becomes the trigger (pole 86)
