Vacuum Issue
Old Feb 12, 2017 | 09:21 AM
jap07's Avatar
jap07
Vacuum Issue
Hi..
A couple weeks ago I noticed a significant reduction in power when merging onto the highway. It still ran well enough, no missing, no CEL. Eventually the half power icon came up, but still no CEL. After inspect the car I realized that the vacuum line between turbo and vacuum tank (number 3 on diagram) was not connected and very fragile, so I have order a new one but when I was connecting the new one I was no able to find the vacuum tank (number 1 on diagram), someone of you know where it is located?
Thanks in advance..
DIAGRAM:
http://parts.miniofkennesaw.com/show...category=19711
Old Feb 12, 2017 | 10:53 PM
oldbrokenwind's Avatar
oldbrokenwind
Originally Posted by jap07
Hi..
Thanks in advance..
DIAGRAM:
Try looking below the intake manifold. Not really easy to access.
Old Feb 13, 2017 | 05:33 PM
jap07's Avatar
jap07
Thanks... I'll do that on weekend when have time,,, the last time I was trying to find the vacuum tank from below the car by putting it on a ramp, because I was trying to avoid removing intake manifold, but if there is not other way I think that I will start taking out parts around xD....
Old Feb 14, 2017 | 02:59 PM
nkfry's Avatar
nkfry
If the half power light is on there are codes stored, but you need a dealer level tool to read them.
Those vacuum lines to the reservoir are prone to oil saturation and they fall off over time, once you've got new line installing them shouldn't take long, just make sure to do the job with the car cold, it's not pleasant to work around that exhaust when it's warm.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Feb 20, 2017 | 08:45 PM
jap07's Avatar
jap07
Hi all,
Thanks for your help,... I've fixed the problem yesterday (02/19/2017)... by following this step by step tutorial I've partially removed the manifold intake to get access to the vacuum tank:
https://www.northamericanmotoring.co...-procedure.pdf
It's not clear but the vacuum tank is right there:
Well, now the car runs really nice, Also I've changed the oil (mobil full synthetic 0-40), spark plugs (NGK 95770 ILZKBR7B8DG Laser Iridium Plug) and a K&N air filter(
33-2936)......
Thanks..
Old Feb 21, 2017 | 11:50 AM
nkfry's Avatar
nkfry
Good to hear you fixed it. I see there is oil in the area of the vacuum lines, did you replace the soft hoses for the vacuum lines? Oil saturation will cause those lines to swell and not seal right causing them to eventually to fall off again. If you didn't replace the sections of line I would recommend it.
Phone:586-792-6464
Old Feb 21, 2017 | 12:49 PM
jap07's Avatar
jap07
Thanks.....Yes I've replaced the soft hoses by new ones from ecstuning https://www.ecstuning.com/b-genuine-...e/11657570465/... the old ones were very brittle..
