Suspension Ride Height Suggestions
Old Feb 9, 2017 | 01:34 PM
sillydanhy's Avatar
sillydanhy
I just got ST Suspension for my R56. I am not using any camber kits. I am curious what height is good for the front middle arch to the ground and the rear middle arch to the ground.
Please advise
Thanks!
Old Feb 14, 2017 | 05:19 AM
sillydanhy's Avatar
sillydanhy
bump
Old Feb 16, 2017 | 01:24 PM
nkfry's Avatar
nkfry
All depends on if you want a functional suspension, or if you want to rub everything you come into contact with.
Do you want "stance points" or function?
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Feb 16, 2017 | 04:31 PM
RB-MINI's Avatar
RB-MINI
This thread has some good info on the Gen 2's with ST's, but it looks like all of the pics are gone except from this post:
https://www.northamericanmotoring.co...ml#post3364413
Depending on your wheel offset and how low you go, you might need to add at least 5mm spacers to clear the bottom spring perch in the front.
