Turning Noise/Squeaking
Old Feb 3, 2017 | 10:37 AM
goj210's Avatar
goj210
Yesterday my 2009 R56 started making an odd noise when turning left.
This is what is sounds like:
https://goo.gl/photos/Ue9zxmpUpNTxuW246
I thought it might be the wheel bearings, but I don't have experience checking them. I did jack the car up to see how the felt/sounded. It wasn't great, but I don't have a good baseline. It might be a seperate issue and I should replace those anyways.
https://goo.gl/photos/MXmUSLPQ1TeiYiy36
You guys have any thoughts?
Thanks!
Old Feb 3, 2017 | 11:19 AM
nkfry's Avatar
nkfry
Have a look at your brake dust shields and wheel bearings.
Sounds tinny enough that I would suspect dust shields before anything expensive.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Feb 6, 2017 | 06:22 AM
goj210's Avatar
goj210
Thanks for the quick reply. I popped the wheel off and did some light cleaning around the brake rotor. Didn't see anything obvious, but the noise stopped.
I was planning on taking off the brake rotor and doing a more thorough cleaning. Hopefully it doesn't come back!
Thanks again.
Old Feb 6, 2017 | 09:27 PM
renchjeep's Avatar
renchjeep
If I could figure how to post a vid of my noise, I would. Only happens at low speeds, especially when turning hard left while braking lightly, like into a driveway or parking spot. Or around the circle at the end of my driveway, when coming to a stop. Not like a brake squeal, sounds like something is rubbing, creating this "howl" kinda noise. I will take my front wheels off and inspect everything soon. But I know that my brake pads are thick, rotors are fine, and I have not hit anything recently that could have moved something like a dust or heat shield out of position. I guess I need someone to give me advice on how to post a quick vid here? It is very easy to replicate.
Old Feb 7, 2017 | 07:13 AM
goj210's Avatar
goj210
If you have a gmail account, you have access to google photos. I used google photos, which backs up automatically from my phone. You can also upload from your computer. There is an option to share the link then, which I how I did it above.
Youtube would work as well.
