Catalyst clogging and oil burning
Old Jan 26, 2017 | 01:10 AM
genik's Avatar
genik
Is it true that R56S minis that burn engine oil, have the tendency to clog the catalyst?
Old Feb 3, 2017 | 11:22 AM
nkfry's Avatar
nkfry
I've never seen a clogged cat on these cars. I've seen Coopers that have holes in the catalysts due to massive oil consumption though.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Feb 3, 2017 | 01:07 PM
genik's Avatar
genik
How did u manage to see the hole in the catalyst? Can one open it to have a look?
Old Feb 3, 2017 | 01:27 PM
nkfry's Avatar
nkfry
Ironically I only seen them because I was replacing the oil filter housing gasket which was leaking coolant profusely. The header has to come off to replace that gasket and that's when I noticed oil coked stalagmites in all the exhaust runners and a hole beginning in either side of the cat. The car also had catalyst inefficiency codes and bank 1 sensor 2 rich condition codes.
You could always use a boroscope to see precat through the lambda sensor port, and post cat through the monitoring oxygen sensor port.
Phone:586-792-6464
Old Feb 3, 2017 | 01:31 PM
genik's Avatar
genik
You saw holes that had drilled the metal that housed the catalyst?
